주요 콘텐츠로 건너뛰기
Sony Xperia XZ2 LCD Screen Replacement
필요한 것
  1. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
    • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
    • The phone gets very hot and can hurt the user handling it.
  2. Sony Xperia XZ2 LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Sony Xperia XZ2 LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Sony Xperia XZ2 LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
    • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
  3. Sony Xperia XZ2 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Sony Xperia XZ2 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
    • The screen is still attached by a connector, so do not pull the pieces apart.
  4. Sony Xperia XZ2 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $3.99
    • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
  5. Sony Xperia XZ2 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Gently remove the connector by using a spudger to pop it off.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Matthew Ionescu
회원 가입일: 01/24/19
445 평판
안내서 2개를 작성함
Cal Poly, Team S19-G5, White Winter 2019 Cal Poly, Team S19-G5, White Winter 2019 회원
CPSU-WHITE-W19S19G5
4 회원들
안내서 12개를 작성함
4가이드 댓글
Worked perfectly fine for my xz2 compact
Maria Schrenk - 답글
Hi, someone knows how to glue it back. I read that if I use B-6000 glue it will damage my screen.
Diego Covenas - 답글
Double-sided adhesive should do the trick. For example 2mm Universal 3M Adhesive Tape should be preferred to glue.
Célestin Taramarcaz -
The XZ2 Compact has the same screen connector+clip.
My screen came without the upper speaker grille (plastic+fabric). When I tried to remove the glue from the old one the fabric got delaminated from the plastic. Tip: Check if the grille is in place before gluing back!
Dimitrios Josef Moustos - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 81
전체 시간: 10,985
