주요 콘텐츠로 건너뛰기
Sony Xperia Z Front Facing Camera Replacement
필요한 것
  1. Sony Xperia Z Front Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 Sony Xperia Z Front Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 Sony Xperia Z Front Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Turn hair dryer to medium heat.
    • Slowly move the hair dryer along the seams on the back of the phone. Keep the dryer a few inches away from the case.
    • Circulate the dryer for a full minute to soften the adhesive binding the phone together.
  2. Sony Xperia Z Front Facing Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Once the adhesive is loosened, stick the suction cup to the top-center of the back of your phone and gently pull back.
    • Gently pull back just enough to create a small gap.
  3. Sony Xperia Z Front Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 Sony Xperia Z Front Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Once you've opened a small space with the back cover, stick the plastic opening tool into the seam of the phone.
    • Move the tool along the seam to loosen the adhesive.
  4. Sony Xperia Z Front Facing Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Caution: Pulling too vigorously or quickly on the suction cup could snap the back of the phone.
    • Once the adhesive has been adequately loosened, pull back slowly on the suction cup to remove the back panel of the phone.
    • The remaining adhesive should be strong enough to hold the phone together tightly upon reassembly. However, once opened the water resistance of your phone has been compromised.
  5. Sony Xperia Z Front Facing Camera Replacement: 5 단계, 이미지 3개 중 1개 Sony Xperia Z Front Facing Camera Replacement: 5 단계, 이미지 3개 중 2개 Sony Xperia Z Front Facing Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Now that the back is removed, the battery is visible. You now have access to the battery and its connecting components.
    • With the plastic opening tool, gently remove the connector from the motherboard.
    • Use your fingers to peel the rest of the adhesive away from the phone.
  6. Sony Xperia Z Front Facing Camera Replacement: 6 단계, 이미지 3개 중 1개 Sony Xperia Z Front Facing Camera Replacement: 6 단계, 이미지 3개 중 2개 Sony Xperia Z Front Facing Camera Replacement: 6 단계, 이미지 3개 중 3개
    • With the plastic opening tool, carefully peel the white adhesive tape up from the bottom of the battery.
    • Use your fingers to peel back the rest of the adhesive tape away from the battery.
  7. Sony Xperia Z Front Facing Camera Replacement: 7 단계, 이미지 3개 중 1개 Sony Xperia Z Front Facing Camera Replacement: 7 단계, 이미지 3개 중 2개 Sony Xperia Z Front Facing Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
    • Flex cables run vertically down the phone underneath the battery and can be damaged easily. Make sure to only place the spudger in the indicated area.
    • Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
  8. Sony Xperia Z Front Facing Camera Replacement, Camera: 8 단계, 이미지 1개 중 1개
    • Remove the one 3 mm screw with the Phillips #000 screwdriver. The screw is located at the top right corner of the motherboard. The motherboard is the green/silver circuit board at the top of the phone.
  9. Sony Xperia Z Front Facing Camera Replacement: 9 단계, 이미지 3개 중 1개 Sony Xperia Z Front Facing Camera Replacement: 9 단계, 이미지 3개 중 2개 Sony Xperia Z Front Facing Camera Replacement: 9 단계, 이미지 3개 중 3개
    • Using with the plastic opening tool, pry up firmly from the bottom and top of the plastic housing. The housing is black and located at the top right corner of the phone.
    • Release the charging cover, located on the right side of the phone at the top. This should cause the housing piece to pop out effortlessly.
    • Getting the black housing off of the phone can be tricky. Just keep prying and pulling up on the housing to get it out.
  10. Sony Xperia Z Front Facing Camera Replacement, Front Facing Camera: 10 단계, 이미지 2개 중 1개 Sony Xperia Z Front Facing Camera Replacement, Front Facing Camera: 10 단계, 이미지 2개 중 2개
    • With the plastic opening tool, gently pry the red tape away from motherboard. This pop connector is located at the top right corner of the phone.
    • Using your fingers, gently pull up on the pop connector to remove the front camera. The front camera piece should lift out effortlessly.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Emily Holland
회원 가입일: 02/02/14
2,344 평판
안내서 4개를 작성함
Cal Poly, Team 2-7, Amido Winter 2014 Cal Poly, Team 2-7, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G7
4 회원들
안내서 25개를 작성함
1가이드 댓글
Does the black housing over secondary camera has any connectors in it? Where does the antenna next to secondary camera attach itself to?
Ananya - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 32
전체 시간: 11,953
