주요 콘텐츠로 건너뛰기
Sony Xperia Z Ultra Motherboard Replacement
필요한 것
  1. Sony Xperia Z Ultra Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Use the small suction cup to lift the back panel:
    • Press the small suction cup on to the middle of the back panel.
  2. Sony Xperia Z Ultra Motherboard Replacement: 2 단계, 이미지 1/1
    • While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
    • While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
    • Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
  3. Sony Xperia Z Ultra Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the back panel by pulling the small suction cup upwards.
  4. Sony Xperia Z Ultra Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the following six screws with a Phillips #000 screwdriver:
    • five silver 2.1 mm screws
    • one gold 3.1 mm screw
  5. Sony Xperia Z Ultra Motherboard Replacement: 5 단계, 이미지 1/1
    • Pry the plastic motherboard shield open by placing the spudger under the shield and running it along the edges.
  6. Sony Xperia Z Ultra Motherboard Replacement: 6 단계, 이미지 1/1
    • Use care to remove the motherboard shield, as it may break. The motherboard shield is made of a very thin plastic.
    • Remove the motherboard shield by lifting the lower end upwards first.
  7. Sony Xperia Z Ultra Motherboard Replacement: 7 단계, 이미지 1/2 Sony Xperia Z Ultra Motherboard Replacement: 7 단계, 이미지 2/2
    • Detach the battery connection cable by prying it upward with the spudger.
  8. Sony Xperia Z Ultra Motherboard Replacement: 8 단계, 이미지 1/1
    • Pry the upper end of the antenna upwards with the spudger.
  9. Sony Xperia Z Ultra Motherboard Replacement: 9 단계, 이미지 1/1
    • Detach the antenna by pulling the upper end upwards and outwards.
  10. Sony Xperia Z Ultra Motherboard Replacement: 10 단계, 이미지 1/1
    • Insert the spudger underneath the battery and run it back and forth to remove any adhesive.
  11. Sony Xperia Z Ultra Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the battery from the phone.
  12. Sony Xperia Z Ultra Motherboard Replacement, Motherboard: 12 단계, 이미지 1/1
    • Pry the antenna assembly upwards with the spudger.
  13. Sony Xperia Z Ultra Motherboard Replacement: 13 단계, 이미지 1/1
    • You should hear a slight "click" when the antenna assembly has been completely loosened.
    • Remove the antenna assembly by pulling it upwards from the right end.
  14. Sony Xperia Z Ultra Motherboard Replacement: 14 단계, 이미지 1/1
    • Remove the mic cover by placing the spudger underneath the cover and prying it upward.
  15. Sony Xperia Z Ultra Motherboard Replacement: 15 단계, 이미지 1/1
    • The metal shield is very thin, so use care to remove the metal shield as it can easily be bent.
    • Remove the metal shield cover by prying its right end upwards with the flat part of the spudger.
  16. Sony Xperia Z Ultra Motherboard Replacement: 16 단계, 이미지 1/1
    • Remove the mic connection from the motherboard ribbon by prying it upwards with the spudger.
    • Once released, the orange ribbon will resemble a flap.
  17. Sony Xperia Z Ultra Motherboard Replacement: 17 단계, 이미지 1/2 Sony Xperia Z Ultra Motherboard Replacement: 17 단계, 이미지 2/2
    • Use care to remove the black plastic spacer, as it may bend if excessive force is used. The black plastic spacer is very thin and extremely fragile.
    • Gently pry the black plastic spacer upwards with the spudger.
    • Remove the black plastic spacer from the phone by gently pulling it upwards.
  18. Sony Xperia Z Ultra Motherboard Replacement: 18 단계, 이미지 1/1
    • Release the LCD digitizer connection by prying it upwards with the spudger.
    • The LCD digitizer is distinguished by a longer connection strip.
  19. Sony Xperia Z Ultra Motherboard Replacement: 19 단계, 이미지 1/2 Sony Xperia Z Ultra Motherboard Replacement: 19 단계, 이미지 2/2
    • Use care to detach the vibration motor connection, as it may break if excessive pressure is applied. The vibration motor connection is tiny and fragile.
    • Use the flat part of a spudger to detach the vibration motor connection. It is a tiny white box with red and black wires leading to the motor.
    • Once the connection has been removed, slide the spudger underneath the vibration motor to release it from the adhesive.
  20. Sony Xperia Z Ultra Motherboard Replacement: 20 단계, 이미지 1/2 Sony Xperia Z Ultra Motherboard Replacement: 20 단계, 이미지 2/2
    • Remove the loudspeaker connection by prying it upwards with the spudger.
  21. Sony Xperia Z Ultra Motherboard Replacement: 21 단계, 이미지 1/1
    • Remove the orange ribbon connection by prying it upwards with the spudger.
  22. Sony Xperia Z Ultra Motherboard Replacement: 22 단계, 이미지 1/2 Sony Xperia Z Ultra Motherboard Replacement: 22 단계, 이미지 2/2
    • Pry the small black metal bracket off with the spudger.
    • Gently remove the ribbons that are attached to the side of the phone to avoid cracking them.
    • Remove the small black metal bracket by lifting it upwards and outwards.
  23. Sony Xperia Z Ultra Motherboard Replacement: 23 단계, 이미지 1/1
    • Detach the orange ribbon by wedging the spudger between the phone's casing and the ribbon. This will help prevent damage to the strip.
  24. Sony Xperia Z Ultra Motherboard Replacement: 24 단계, 이미지 1/1
    • Detach smaller orange ribbon by wedging the spudger between the phone's casing and the ribbon. This will help prevent damage to the strip.
  25. Sony Xperia Z Ultra Motherboard Replacement: 25 단계, 이미지 1/2 Sony Xperia Z Ultra Motherboard Replacement: 25 단계, 이미지 2/2
    • All parts connected to the motherboard with an orange ribbon are fragile and should be treated with extreme care.
    • Pry up the connection strip at the end of the motherboard using the flat part of the spudger to free the motherboard.
    • The connection strip has adhesive underneath.
  26. Sony Xperia Z Ultra Motherboard Replacement: 26 단계, 이미지 1/1
    • Manually remove the copper tape anchoring the motherboard's black ribbon.
    • When removing the motherboard in its entirety, make sure all securing points have been released.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Omar Herrera
회원 가입일: 10/07/15
1,324 평판
안내서 1개 작성함
Cal Poly, Team 4-6, Maness Fall 2015 Cal Poly, Team 4-6, Maness Fall 2015 회원
CPSU-MANESS-F15S4G6
4 회원들
안내서 10개 작성하였습니다
댓글 11개
Most grateful very helpful and easy to follow thank you very much
Edward - 답글
please help me how to solder the flex cable to the motherboard
jawadsupercool - 답글
very helpful. thanks.
can anyone suggest me where to buy the motherboard of sony z ultra?
neko - 답글
Can anyone tell me how to replace flex connected to motherboard. Sony z ultra 4g
smaran727 - 답글
how much this board..???
anak zalal - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 28
전체 시간: 9,671
