주요 콘텐츠로 건너뛰기
Sony Xperia Z1 - Password Removal, Firmware update with PC Companion
동영상 개요
  1. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 1 단계, 이미지 1/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 1 단계, 이미지 2/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 1 단계, 이미지 3/3
  2. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 2 단계, 이미지 1/2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 2 단계, 이미지 2/2
    • Insert wisdom here.
  3. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 3 단계, 이미지 1/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 3 단계, 이미지 2/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 3 단계, 이미지 3/3
    • From here you can update your device firmware but it must be unlocked (device can't be in lock screen).
    • Start the new PC Companion function "Support Zone".
    • PC Companion will download some necessary files and you are ready to start "Phone / Tablet Software Update".
  4. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 4 단계, 이미지 1/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 4 단계, 이미지 2/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 4 단계, 이미지 3/3
    • Your laptop must be connected to the power adapter.
    • Select "repair my phone / tablet".
    • The last warning for your personal data
  5. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 5 단계, 이미지 1/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 5 단계, 이미지 2/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 5 단계, 이미지 3/3
    • After PC Companion prepared your laptop for the update, you must choose the model of your device.
    • The battery must be at last 80% charged.
    • Doesn't make a mistake in choosing the model.
  6. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 6 단계, 이미지 1/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 6 단계, 이미지 2/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 6 단계, 이미지 3/3
    • Switch of the phone. If you have a problem with the Android OS and you can't switch it off, then press and hold the power on button for a long time, or use the reset button under the micro SIM cover.
    • Press and hold the volume down button and then insert the micro USB cable.
    • Your PC will recognize the phone and PC Companion will download the latest version for your device and will flash it.
  7. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 7 단계, 이미지 1/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 7 단계, 이미지 2/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 7 단계, 이미지 3/3
    • If your PC doesn't recognize you phone (SOMC Flash Device), you must install drivers for it.
    • S1Boot Fasboot drivers
  8. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 8 단계, 이미지 1/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 8 단계, 이미지 2/3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 8 단계, 이미지 3/3
    • When PC Companion finished updating, disconnect the phone and switch it on.
    • Your device is with latest firmware, in factory state, without personal data and security.
    • Please SUBSCRIBE to my channel ツ
결론
다른 19명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 3개
Thank you, this was really helpful.
DOWNLOAD AND UPDATE FIRMWARE SONY XPERIA XZ 601SO gofirmware
Jacky888 Jacky888 - 답글
which version is it? sony companion doesnt let you do it in latest. plz reply
DcKnown by Public - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 21,093
