주요 콘텐츠로 건너뛰기
Sony Xperia Z1 Soft / Hard Reset
필요한 것
동영상 개요
  1. Sony Xperia Z1  Soft / Hard Reset, Sony Xperia Z1  Soft / Hard Reset: 1 단계, 이미지 1/3 Sony Xperia Z1  Soft / Hard Reset, Sony Xperia Z1  Soft / Hard Reset: 1 단계, 이미지 2/3 Sony Xperia Z1  Soft / Hard Reset, Sony Xperia Z1  Soft / Hard Reset: 1 단계, 이미지 3/3
    • SOFT RESET
    • You can force your device to shut down in situations where it stops responding or won't restart normally. No settings or personal data get deleted.
    • Micro SD card cover
    • Micro USB connector cover
    • Micro SIM card cover
    • Open the micro SIM card cover and you will see a small red button. Press it and you will feel three vibrations and device will shuts down.
  2. Sony Xperia Z1  Soft / Hard Reset: 2 단계, 이미지 1/3 Sony Xperia Z1  Soft / Hard Reset: 2 단계, 이미지 2/3 Sony Xperia Z1  Soft / Hard Reset: 2 단계, 이미지 3/3
    • FACTORY DATA / HARD RESET
    • Go to Settings > Backup & Reset
    • You have option to backup your data (you must have Google account).
    • After Factory data reset the smartphone will restart.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
결론
다른 69명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,341 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,540개 작성하였습니다
댓글 29개
I will alrrady presss red bottan then he 3time vibration after no responses. Why I want to broken my pattern lock ...pls help
ansarigroups63 - 답글
the same as yours
Tioti Aukitino -
forget my paaword
Tioti Aukitino -
i cant get into my menu
roelienesterhuyse48 - 답글
http://bfast.ir
اصول صحیح مطالعه
mirmahdi jafari - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 85
30일 전: 257
전체 시간: 528,877
