주요 콘텐츠로 건너뛰기
Sony Xperia Z1 Battery Replacement
필요한 것
  1. Sony Xperia Z1 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before you begin, use caution while handling a heat gun.
    • With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
  2. Sony Xperia Z1 Battery Replacement: 2 단계, 이미지 1/2 Sony Xperia Z1 Battery Replacement: 2 단계, 이미지 2/2
    • Apply a suction cup tool to the center of the back panel and gently pull the panel off the back of the phone.
    • If you are experiencing difficulty, use an opening pick to slide into the crack in between the panel and the rest of the phone body to pry off the back.
  3. Sony Xperia Z1 Battery Replacement: 3 단계, 이미지 1/2 Sony Xperia Z1 Battery Replacement: 3 단계, 이미지 2/2
    • Use the Torx T5 screwdriver to remove the two 3.81mm screws from the corners of the battery.
  4. Sony Xperia Z1 Battery Replacement: 4 단계, 이미지 1/2 Sony Xperia Z1 Battery Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to gently pry off the two flex connectors from the motherboard. Getting access to one of the connectors requires prying off the other first, so be sure to remove the top connector first.
    • Tip: you may need to use the tweezers to gently hold the top connector out of the way while prying off the bottom connector.
  5. Sony Xperia Z1 Battery Replacement: 5 단계, 이미지 1/1
    • Slowly slip the halberd spudger underneath the rest of the orange flex cable to carefully peel the adhesive portion away from the rest of the phone.
  6. Sony Xperia Z1 Battery Replacement: 6 단계, 이미지 1/1
    • Use the tweezers to grab the top right corner of battery and carefully lift it up and away from the phone.
  7. Sony Xperia Z1 Battery Replacement: 7 단계, 이미지 1/1
    • Once the battery is at a safe enough height, grip the corner of the battery and slowly pull it out of the phone.
    • The old battery can be recycled at any local office supply store that supports recycling used batteries.
결론
Elijah Sigua
회원 가입일: 01/30/20
255 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 24
30일 전: 82
전체 시간: 2,768
