주요 콘텐츠로 건너뛰기
Sony Xperia Z1 Compact Battery Replacement
필요한 것
  1. Sony Xperia Z1 Compact Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Battery Replacement: 2 단계, 이미지 1/1
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Battery Replacement: 3 단계, 이미지 1/2 Sony Xperia Z1 Compact Battery Replacement: 3 단계, 이미지 2/2
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
  4. Sony Xperia Z1 Compact Battery Replacement, Battery: 4 단계, 이미지 1/2 Sony Xperia Z1 Compact Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
  5. Sony Xperia Z1 Compact Battery Replacement: 5 단계, 이미지 1/2 Sony Xperia Z1 Compact Battery Replacement: 5 단계, 이미지 2/2
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
  6. Sony Xperia Z1 Compact Battery Replacement: 6 단계, 이미지 1/1
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
  7. Sony Xperia Z1 Compact Battery Replacement: 7 단계, 이미지 1/1
    • Remove the battery from the device
결론
다른 12명이 해당 안내서를 완성하였습니다.
kinan badr
회원 가입일: 09/21/17
386 평판
안내서 1개 작성함
Washington State, Team S4-G1, Phelps-Hillen Fall 2017 Washington State, Team S4-G1, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S4G1
6 회원들
안내서 9개 작성하였습니다
댓글 3개
is there any reliable source for good replacement battery purchase?
Upendra Gandhi - 답글
What is the Ariel stuck on the battery ?
Tony - 답글
NFC Antenna. You should carefully transplant it to new battery, in case your new battery is without one (what is the case for most 3rd party batteries available)
Peter Pepo -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 29
전체 시간: 11,547
