소개
This guide will show you how to replace the earpiece speaker that no longer works.
필요한 것
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
