소개
This guide will show you how you replace the headphone jack.
필요한 것
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
To remove the headphone jack, cut the sticker between the headphone jack and the midframe with sharp tweasers.
거의 끝나갑니다!
결론
