주요 콘텐츠로 건너뛰기
Sony Xperia Z1 Compact Headphone Jack Replacement Replacement
필요한 것
  1. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement, Back Cover: 1 단계, 이미지 1/1
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 2 단계, 이미지 1/1
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 3 단계, 이미지 1/2 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 3 단계, 이미지 2/2
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
  4. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement, Battery: 4 단계, 이미지 1/2 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement, Battery: 4 단계, 이미지 2/2
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
  5. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 5 단계, 이미지 1/2 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 5 단계, 이미지 2/2
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
  6. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 6 단계, 이미지 1/1
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
  7. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 7 단계, 이미지 1/1
    • Remove the battery from the device
  8. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement, External Speaker: 8 단계, 이미지 1/2 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement, External Speaker: 8 단계, 이미지 2/2
    • Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
  9. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 9 단계, 이미지 1/3 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 9 단계, 이미지 2/3 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 9 단계, 이미지 3/3
    • Wedge the plastic opening tool under the back frame. Move the plastic opening tool around the entire frame to separate it from the adhesive.
  10. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 10 단계, 이미지 1/1
    • Remove the back frame.
  11. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 11 단계, 이미지 1/2 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 11 단계, 이미지 2/2
    • Wedge the spudger underneath the external speaker. Pull up on the external speaker using the spudger.
  12. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 12 단계, 이미지 1/2 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 12 단계, 이미지 2/2
    • Remove the external speaker.
  13. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement, Motherboard: 13 단계, 이미지 1/2 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement, Motherboard: 13 단계, 이미지 2/2
    • Remove the square rubber gasket from the camera using the plastic spudger.
  14. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 14 단계, 이미지 1/2 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 14 단계, 이미지 2/2
    • Remove the black plastic corner still holding in the motherboard.
  15. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 15 단계, 이미지 1/3 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 15 단계, 이미지 2/3 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 15 단계, 이미지 3/3
    • Carefully pry up on the four sides of the motherboard using the plastic spudger til it separates from the base of the phone.
  16. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 16 단계, 이미지 1/3 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 16 단계, 이미지 2/3 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 16 단계, 이미지 3/3
    • Remove the motherboard from the device.
    • There may be a small yellow adhesive underneath the motherboard still holding it in. Slide the tip of the spudger through it to sever it.
  17. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement, Headphone Jack Replacement: 17 단계, 이미지 1/2 Sony Xperia Z1 Compact Headphone Jack Replacement Replacement, Headphone Jack Replacement: 17 단계, 이미지 2/2
    • To remove the headphone jack, cut the sticker between the headphone jack and the midframe with sharp tweasers.
  18. Sony Xperia Z1 Compact Headphone Jack Replacement Replacement: 18 단계, 이미지 1/1
    • Remove the headphone jack.
결론
Frani Morris
회원 가입일: 09/21/17
222 평판
안내서 2개 작성하였습니다
Washington State, Team S4-G1, Phelps-Hillen Fall 2017 Washington State, Team S4-G1, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S4G1
6 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 1,241
