주요 콘텐츠로 건너뛰기
Sony Xperia Z1 Compact Screen Replacement
필요한 것
  1. Sony Xperia Z1 Compact Screen Replacement, Apply heat: 1 단계, 이미지 1/1
    • Apply heat to the edges.
  2. Sony Xperia Z1 Compact Screen Replacement, Start prying: 2 단계, 이미지 1/1
    • When the glue is warm slowly start prying from the top corner.
  3. Sony Xperia Z1 Compact Screen Replacement, Add more heat if necessary: 3 단계, 이미지 1/1
    • If the glue is cooled down heat more. Don't force it.
  4. Sony Xperia Z1 Compact Screen Replacement, Cable: 4 단계, 이미지 1/1
    • Remove the data cable from the phones body.
  5. Sony Xperia Z1 Compact Screen Replacement, Testing new screen: 5 단계, 이미지 1/1
    • Test if the new screen works properly.
  6. Sony Xperia Z1 Compact Screen Replacement, The tape: 6 단계, 이미지 1/1
    • If the screen works, remove the new screen and add the double sided tape
  7. Sony Xperia Z1 Compact Screen Replacement, Connecting new screen: 7 단계, 이미지 1/1
    • Connect the new screen to the phone.
  8. Sony Xperia Z1 Compact Screen Replacement, Apply force: 8 단계, 이미지 1/1
    • Now push town not to tight not to softly to the screen.
    • And that's it. You finished the screen replacement.
결론
다른 30명이 해당 안내서를 완성하였습니다.
jaanparker
회원 가입일: 01/21/16
952 평판
안내서 1개 작성함
댓글 5개
There is a very good Youtube video of this. I think these are screenshots from it.
Andrew - 답글
Good video! Help me too! Thanks
Clodoaldo Castro - 답글
There is a thin, soft foam layer on the backside of the factory screen assembly, right behind the LCD backlight. This insulation foam is missing from most replacement screens. It can be peeled off relatively easily, but it will not stick easily onto the replacement LCD. I am not sure whether it is required at all, does anybody have experience and recommendations concerning this?
sinistre - 답글
My lcd burn before use Heat gun! Very sad!
Use t7000 glue for glueing screen back down,sure way of it not lifting off
Marcus Roach - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 17,669
