주요 콘텐츠로 건너뛰기
Sony Xperia Z1 Rear Camera Replacement
필요한 것
  1. Sony Xperia Z1 Rear Camera Replacement, Rear Camera: 1 단계, 이미지 1/1
    • With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
  2. Sony Xperia Z1 Rear Camera Replacement: 2 단계, 이미지 1/2 Sony Xperia Z1 Rear Camera Replacement: 2 단계, 이미지 2/2
    • Apply a suction cup tool to the center of the back panel and gently pull the panel off the back of the phone.
    • If you are experiencing difficulty, use a plastic opening pick to slide into the crack in between the panel and the rest of the phone body to pry off the back.
  3. Sony Xperia Z1 Rear Camera Replacement: 3 단계, 이미지 1/2 Sony Xperia Z1 Rear Camera Replacement: 3 단계, 이미지 2/2
    • Using the plastic opening tool, carefully pry off the flex connector beside the camera housing.
  4. Sony Xperia Z1 Rear Camera Replacement: 4 단계, 이미지 1/2 Sony Xperia Z1 Rear Camera Replacement: 4 단계, 이미지 2/2
    • Use the tweezers to pull the camera out of the top left corner of the phone.
결론
Elijah Sigua
회원 가입일: 01/30/20
255 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 307
