주요 콘텐츠로 건너뛰기
Sony Xperia Z2 Earpiece Replacement
필요한 것
동영상 개요
  1. Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: 1 단계, 이미지 3개 중 1개 Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: 1 단계, 이미지 3개 중 2개 Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: 1 단계, 이미지 3개 중 3개
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Earpiece Replacement: 2 단계, 이미지 3개 중 1개 Sony Xperia Z2 Earpiece Replacement: 2 단계, 이미지 3개 중 2개 Sony Xperia Z2 Earpiece Replacement: 2 단계, 이미지 3개 중 3개
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Earpiece Replacement: 3 단계, 이미지 2개 중 1개 Sony Xperia Z2 Earpiece Replacement: 3 단계, 이미지 2개 중 2개
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Earpiece Replacement, Battery: 4 단계, 이미지 3개 중 1개 Sony Xperia Z2 Earpiece Replacement, Battery: 4 단계, 이미지 3개 중 2개 Sony Xperia Z2 Earpiece Replacement, Battery: 4 단계, 이미지 3개 중 3개
  5. Sony Xperia Z2 Earpiece Replacement, Logic Board: 5 단계, 이미지 2개 중 1개 Sony Xperia Z2 Earpiece Replacement, Logic Board: 5 단계, 이미지 2개 중 2개
    • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
  6. Sony Xperia Z2 Earpiece Replacement: 6 단계, 이미지 3개 중 1개 Sony Xperia Z2 Earpiece Replacement: 6 단계, 이미지 3개 중 2개 Sony Xperia Z2 Earpiece Replacement: 6 단계, 이미지 3개 중 3개
  7. Sony Xperia Z2 Earpiece Replacement, Earpiece: 7 단계, 이미지 1개 중 1개
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 3개
Would be nice with a comment on how to remove the earpiece.
Since the phone is waterresistance the headjack and earpiece are taped to the body which makes that you need to buy a new sparepart, but look out on ebay that you get a part with tape to it.
Claes - 답글
After having done the removal of the earpiece you will have to, either buy a new adhesive for the earpice or a new earpiece. But be aware some spareparts are sold without adhesive.
Claes -
I accidentally torn apart one of the cables( vibrate cable:the brown one) I'm messed up! Vibration not working. What can I do? Where can I buy one of those cables? Please reply!
Mahtab - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 19
전체 시간: 7,691
