주요 콘텐츠로 건너뛰기
Sony Xperia Z2 Loudspeaker Replacement
필요한 것
동영상 개요
  1. Sony Xperia Z2 Loudspeaker Replacement, Rear / Battery Cover: 1 단계, 이미지 1/3 Sony Xperia Z2 Loudspeaker Replacement, Rear / Battery Cover: 1 단계, 이미지 2/3 Sony Xperia Z2 Loudspeaker Replacement, Rear / Battery Cover: 1 단계, 이미지 3/3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Loudspeaker Replacement: 2 단계, 이미지 1/3 Sony Xperia Z2 Loudspeaker Replacement: 2 단계, 이미지 2/3 Sony Xperia Z2 Loudspeaker Replacement: 2 단계, 이미지 3/3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Loudspeaker Replacement: 3 단계, 이미지 1/2 Sony Xperia Z2 Loudspeaker Replacement: 3 단계, 이미지 2/2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Loudspeaker Replacement, Battery: 4 단계, 이미지 1/3 Sony Xperia Z2 Loudspeaker Replacement, Battery: 4 단계, 이미지 2/3 Sony Xperia Z2 Loudspeaker Replacement, Battery: 4 단계, 이미지 3/3
  5. Sony Xperia Z2 Loudspeaker Replacement, Loudspeaker: 5 단계, 이미지 1/3 Sony Xperia Z2 Loudspeaker Replacement, Loudspeaker: 5 단계, 이미지 2/3 Sony Xperia Z2 Loudspeaker Replacement, Loudspeaker: 5 단계, 이미지 3/3
    • Remove the Loudspeaker metal bracket.
  6. Sony Xperia Z2 Loudspeaker Replacement: 6 단계, 이미지 1/3 Sony Xperia Z2 Loudspeaker Replacement: 6 단계, 이미지 2/3 Sony Xperia Z2 Loudspeaker Replacement: 6 단계, 이미지 3/3
    • Part of the Volume/PowerON/Mic flex cable is affixed onto the Loudspeaker/Vibro motor module.
    • Under the Flex cable is the Loudspeaker.
    • You can change only the Loudspeaker or or the Loudspeaker & Holder module.
    • Loudspeaker & Holder module Part No: 1282-2013
    • Please SUBSCRIBE to my channel ツ
결론
다른 4명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 9,607
