주요 콘텐츠로 건너뛰기
Sony Xperia Z2 Main Camera Replacement
필요한 것
동영상 개요
  1. Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: 1 단계, 이미지 1/3 Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: 1 단계, 이미지 2/3 Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: 1 단계, 이미지 3/3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Main Camera Replacement: 2 단계, 이미지 1/3 Sony Xperia Z2 Main Camera Replacement: 2 단계, 이미지 2/3 Sony Xperia Z2 Main Camera Replacement: 2 단계, 이미지 3/3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Main Camera Replacement: 3 단계, 이미지 1/2 Sony Xperia Z2 Main Camera Replacement: 3 단계, 이미지 2/2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Main Camera Replacement, Main Camera: 4 단계, 이미지 1/2 Sony Xperia Z2 Main Camera Replacement, Main Camera: 4 단계, 이미지 2/2
결론
다른 9명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,368 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,468개 작성하였습니다
댓글 7개
Where can I buy Spear main camera bucz my main camera is not functioning. Please help please... Please link me a website where I can buy it online.
Kushal maharjan - 답글
search ebay for "sony xperia z2 camera", unbelievable right?
deftoner -
I crashed my sony z2 and after i fix the screen i but the camera and it's overheated and doesn't work.what i must do and change
chris kat - 답글
I replied the comment to the other guy
deftoner -
My Camara get overheated too, and does not work, trying to replace it, where can I get it replace and how much does it go for thanks
Tripleboss - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 17
전체 시간: 9,129
