소개
Sony Xperia Z2 (D6502, D6503, and D6543) - How to replace the Wi-Fi Antenna
______________ Video manual: ______________
필요한 것
동영상 개요
Switch off the phone.
If you can't switch it off, you can use the OFF button near to the SIM card Tray.
Warm the Back Cover. You can use a hairdryer.
Disconnect the Battery Flex Cable and remove the two Philips screws.
Li-Polymer Battery, 3.8V, 3200mAh
Part number: LIS1543ERPC
다른 11명이 해당 안내서를 완성하였습니다.
댓글 3개
Continu your learning
hi got my Xperia z replace the broken screen and I was told that the antenna is broke, wait over week to get fixed and still the antenna is so weak I couldn't load my Face Book
This guide seems to have been written just to promote the author’s own website. The advice is very poor, misleading and unhelpful.
(1) Removing the back panel will destroy it. All intending any repairs should have a replacement panel available before beginning.
(2) Replacing battery is as described.
(3) Author does not identify the wifi antenna correctly, nor supply advice on replacing it. Actually the wifi antenna is located at the lower right corner of the Xperia Z2 not upper left as shown. A connector wire runs along the edge in a groove and leads up to a connection on the motherboard. To replace wifi antenna unclip the connector, unscrew the mini circuit board, then reverse the steps with new board/connector.
