주요 콘텐츠로 건너뛰기
Sony Xperia Z3 Compact Front Camera Replacement
필요한 것
  1. Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: 1 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: 1 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: 1 단계, 이미지 3개 중 3개
    • Carefully use a heat gun or hairdryer to melt the adhesive holding the rear case to the phone.
    • Use a suction cup to lift the rear case slightly, enough to slide an opening pick around the edge and loosen the adhesive.
    • Remove back cover.
  2. Sony Xperia Z3 Compact Front Camera Replacement: 2 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Front Camera Replacement: 2 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Front Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove the midframe.
    • Be aware that there are small tabs holding the midframe into the frame of the phone. These are located at the top and along the sides. You may need pry gently pry the midframe out with the flat end of a spudger.
  3. Sony Xperia Z3 Compact Front Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the battery flex cable.
  4. Sony Xperia Z3 Compact Front Camera Replacement: 4 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Front Camera Replacement: 4 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Front Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Remove bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  5. Sony Xperia Z3 Compact Front Camera Replacement: 5 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Front Camera Replacement: 5 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Front Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Release connectors and screw.
  6. Sony Xperia Z3 Compact Front Camera Replacement: 6 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Front Camera Replacement: 6 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Front Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Remove motherboard.
  7. Sony Xperia Z3 Compact Front Camera Replacement: 7 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Front Camera Replacement: 7 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Front Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Remove front camera.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Sophia
회원 가입일: 03/25/14
43,905 평판
안내서 62개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 4
전체 시간: 7,089
