주요 콘텐츠로 건너뛰기
Sony Xperia Z3 Compact Midframe Replacement
필요한 것
  1. Sony Xperia Z3 Compact Midframe Replacement, Midframe: 1 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Midframe Replacement, Midframe: 1 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Midframe Replacement, Midframe: 1 단계, 이미지 3개 중 3개
    • First, heat up.
    • And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
    • Finally, remove the back cover.
  2. Sony Xperia Z3 Compact Midframe Replacement: 2 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Midframe Replacement: 2 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Midframe Replacement: 2 단계, 이미지 3개 중 3개
    • Disconnect the NFC flex press connector.
    • Unscrew the screws holding the black midframe in place.
    • Remove back frame.
  3. Sony Xperia Z3 Compact Midframe Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the battery flex cable.
  4. Sony Xperia Z3 Compact Midframe Replacement: 4 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Midframe Replacement: 4 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Midframe Replacement: 4 단계, 이미지 3개 중 3개
    • Remove rear camera bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  5. Sony Xperia Z3 Compact Midframe Replacement: 5 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Midframe Replacement: 5 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Midframe Replacement: 5 단계, 이미지 3개 중 3개
    • Release connectors and twist off screw.
  6. Sony Xperia Z3 Compact Midframe Replacement: 6 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Midframe Replacement: 6 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Midframe Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove motherboard.
    • Lift the red cover off the vibrating motor, and lift the motor with tweezers. The motor should stay attached to the cabling to the motherboard.
  7. Sony Xperia Z3 Compact Midframe Replacement: 7 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Midframe Replacement: 7 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Midframe Replacement: 7 단계, 이미지 3개 중 3개
    • Remove headphone jack.
    • Use caution lifting the flex cables that are stuck to the midplate.
  8. Sony Xperia Z3 Compact Midframe Replacement: 8 단계, 이미지 2개 중 1개 Sony Xperia Z3 Compact Midframe Replacement: 8 단계, 이미지 2개 중 2개
    • Remove loudspeaker.
  9. Sony Xperia Z3 Compact Midframe Replacement: 9 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Midframe Replacement: 9 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Midframe Replacement: 9 단계, 이미지 3개 중 3개
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Sophia
회원 가입일: 03/25/14
43,905 평판
안내서 62개를 작성함
4가이드 댓글
i want to ask what is the purpose of that plastic frame that have some silver paths connecting to the main board, because i accidentally broke it and broke the one path
coleonyx1 - 답글
It is WIFI Antenna connectors
gak.vasilis.far -
I have same issue too did you fix it?
gak.vasilis.far -
This is potentially much more complicated, and fiddly, than the guide suggests - depending on where you get the midframe from, there are a number of additional parts that need moving across to the new one - specifically the rubber seals from the buttons, the small microphone channel near the bottom mic, the plastic defuser for the LED next to the headphone socket and the front camera holder. Removing the lower speaker from the midframe is likely to break it, simply down to the glue being used to hold it in. It's worth making sure you have a replacement to hand as they're fairly cheap.
Additionally to re-emphasise, be very careful with removing the mother board, the vibration motor lead is very delicate and easy to tear. Do make sure it's completely freed up before trying to remove the board!
Daniel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 17,218
