이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replace your Sony Xperia Z3 Compact's midframe.
This involves removing the back panel and front screen, separating the main flex, reattaching it, and then reassembling.
필요한 것
First, heat up.
And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
Finally, remove the back cover.
Separate the LCD screen with earpiece from midframe. See the detail on Sony Xperia Z3 Compact LCD screen replacement guide. Finally, you you can reassemble the phone with new midframe.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 4개
i want to ask what is the purpose of that plastic frame that have some silver paths connecting to the main board, because i accidentally broke it and broke the one path
It is WIFI Antenna connectors
I have same issue too did you fix it?
This is potentially much more complicated, and fiddly, than the guide suggests - depending on where you get the midframe from, there are a number of additional parts that need moving across to the new one - specifically the rubber seals from the buttons, the small microphone channel near the bottom mic, the plastic defuser for the LED next to the headphone socket and the front camera holder. Removing the lower speaker from the midframe is likely to break it, simply down to the glue being used to hold it in. It's worth making sure you have a replacement to hand as they're fairly cheap.
Additionally to re-emphasise, be very careful with removing the mother board, the vibration motor lead is very delicate and easy to tear. Do make sure it's completely freed up before trying to remove the board!
