소개
Use this guide to remove the rear-facing camera in your Sony Xperia Z3 Compact.
필요한 것
Disconnect the NFC antenna.
Unscrew the screws holding the black midframe in place.
Remove midframe.
다른 17명이 해당 안내서를 완성하였습니다.
댓글 4개
Hi i just replaced myxperia z3 compact camera using your Step by step guide. ( Great job on this by the way!) but unfortunately my rear camera is still showing a black screen. What else could be causing this, either hardware or software related?
Same - however Sony seem to be aware of the issue and are not honoring warranty on the device despite being less than 2 years old which is why I am trying this.. Rather annoying. An otherwise usable phone is resigned to the parts box due to an issue with the rear facing camera.
Do I need additional adhesive to reassemble the phone, or the old one will work just fine?
You'll need a new adhesive pad.
