주요 콘텐츠로 건너뛰기
Sony Xperia Z3 Compact Rear Camera Replacement
필요한 것
  1. Sony Xperia Z3 Compact Rear Camera Replacement, Heat the cover glue: 1 단계, 이미지 1개 중 1개
    • Heat up along the edges of the cover to soften the glue.
    • Ideal temperature is around 120 - 150 °C for 60 seconds.
  2. Sony Xperia Z3 Compact Rear Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Place a suction cup on the back cover and pull to open a gap.
    • Insert a guitar pick into the gap and slide it around the corner of the back cover to cut the adhesive sticker.
  3. Sony Xperia Z3 Compact Rear Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Finally, remove the back cover.
    • Be careful, the back cover is fragile and can break.
    • It can be a good idea to wear protective glasses. If the glass shatters, it could enter your eye.
  4. Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: 4 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: 4 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: 4 단계, 이미지 3개 중 3개
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove midframe.
  5. Sony Xperia Z3 Compact Rear Camera Replacement: 5 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Rear Camera Replacement: 5 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Rear Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Disconnect the battery flex connector.
    • Remove rear camera bracket.
  6. Sony Xperia Z3 Compact Rear Camera Replacement: 6 단계, 이미지 3개 중 1개 Sony Xperia Z3 Compact Rear Camera Replacement: 6 단계, 이미지 3개 중 2개 Sony Xperia Z3 Compact Rear Camera Replacement: 6 단계, 이미지 3개 중 3개
    • components on the mainboard are fragile, be careful in the next step.
    • disconnect the flat top cable with a spudger
결론
다른 17명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Sophia
회원 가입일: 03/25/14
43,905 평판
안내서 62개를 작성함
4가이드 댓글
Hi i just replaced myxperia z3 compact camera using your Step by step guide. ( Great job on this by the way!) but unfortunately my rear camera is still showing a black screen. What else could be causing this, either hardware or software related?
Atiyeh - 답글
Same - however Sony seem to be aware of the issue and are not honoring warranty on the device despite being less than 2 years old which is why I am trying this.. Rather annoying. An otherwise usable phone is resigned to the parts box due to an issue with the rear facing camera.
gary mckie -
Do I need additional adhesive to reassemble the phone, or the old one will work just fine?
Giacomo Ciani - 답글
You'll need a new adhesive pad.
gary mckie -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 15
전체 시간: 16,030
