소개
Sony Xperia Z3 battery is non-removable. When you encountered the problem with battery, it's a little complex to replace.
필요한 것
동영상 개요
Heat the back cover to soften the adhesive sticker.
Use the suction cup to open a gap from top side or bottom side.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 2개
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Just finished this guide thank you!
