주요 콘텐츠로 건너뛰기
Sony Xperia Z3 Dual Battery Replacement
필요한 것
동영상 개요
  1. Sony Xperia Z3 Dual Battery Replacement, Battery: 1 단계, 이미지 1/2 Sony Xperia Z3 Dual Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Heat the back cover to soften the adhesive sticker.
    • Use the suction cup to open a gap from top side or bottom side.
  2. Sony Xperia Z3 Dual Battery Replacement: 2 단계, 이미지 1/3 Sony Xperia Z3 Dual Battery Replacement: 2 단계, 이미지 2/3 Sony Xperia Z3 Dual Battery Replacement: 2 단계, 이미지 3/3
    • Insert into the guitar pick and slide to cut the sticker.
    • Remove the back cover.
  3. Sony Xperia Z3 Dual Battery Replacement: 3 단계, 이미지 1/1
    • Release battery flex connector carefully to avoid breaking the pins.
  4. Sony Xperia Z3 Dual Battery Replacement: 4 단계, 이미지 1/1
    • Get free that sticker which for fastening the battery.
  5. Sony Xperia Z3 Dual Battery Replacement: 5 단계, 이미지 1/1
    • Pry up with a little effort because there is adhesive under the battery though not so strong.
  6. Sony Xperia Z3 Dual Battery Replacement: 6 단계, 이미지 1/1
    • That's Sony Xperia Z3 Dual 3100mAh battery.
    • When you finished to replace battery and ready to assemble the phone, you need a piece of new back cover adhesive sticker because it's disposable and the old one can't use any more.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 2개
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Victor Aguirre - 답글
Just finished this guide thank you!
Seb Carroll - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 28,202
