소개
Sony Xperia Z3 battery is non-removable. When you encountered the problem with battery, it's a little complex to replace.
필요한 것
동영상 개요
Heat the back cover to soften the adhesive sticker.
Use the suction cup to open a gap from top side or bottom side.
Insert into the guitar pick and slide to cut the sticker.
Remove the back cover.
In step 5 where it says that there is adhesive on the battery, my adhesive was actually joining the battery to the back plate making this step quite difficult. I had to focus the heat on the backplate right where the battery was and then use a long lever to separate the battery from the back plate.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 2개
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Just finished this guide thank you!
