주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Sony Xperia Z3 Dual Earpiece Speaker Replacement
필요한 것
  1. Sony Xperia Z3 Dual Earpiece Speaker Replacement, Earpiece Speaker: 1 단계, 이미지 1/1
    • Power off and remove two SIM card trays at first before earpiece speaker replacement.
  2. Sony Xperia Z3 Dual Earpiece Speaker Replacement: 2 단계, 이미지 1/3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: 2 단계, 이미지 2/3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: 2 단계, 이미지 3/3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick.
    • Slide guitar pick to cut the sticker.
  3. Sony Xperia Z3 Dual Earpiece Speaker Replacement: 3 단계, 이미지 1/1
    • Remove back cover.
  4. Sony Xperia Z3 Dual Earpiece Speaker Replacement: 4 단계, 이미지 1/3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: 4 단계, 이미지 2/3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: 4 단계, 이미지 3/3
    • It's easy to remove the battery.
  5. Sony Xperia Z3 Dual Earpiece Speaker Replacement: 5 단계, 이미지 1/1
    • Twist off two screws at first.
  6. Sony Xperia Z3 Dual Earpiece Speaker Replacement: 6 단계, 이미지 1/3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: 6 단계, 이미지 2/3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: 6 단계, 이미지 3/3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Earpiece Speaker Replacement: 7 단계, 이미지 1/3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: 7 단계, 이미지 2/3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: 7 단계, 이미지 3/3
    • Release all the connectors connecting with motherboard.
    • Pry motherboard up from left side. It's really hold tightly by some hidden keys, so be careful.
    • Remove motherboard.
  8. Sony Xperia Z3 Dual Earpiece Speaker Replacement: 8 단계, 이미지 1/3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: 8 단계, 이미지 2/3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: 8 단계, 이미지 3/3
    • Remove the blocker beside earpiece speaker and you can see the breakout to pry up the speaker.
    • Remove earpiece speaker finally.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 3개
Thanks for the guide, it worked very well.
Maybe it's worth mentioning that there's a sticker at the back of the battery and you shouldn't be afraid to just pull the battery out.
Steven Kolenberg - 답글
Hai. Can you give me the link to buy the earpiece? Tq
Wafi Sams - 답글
Thanks for the guide, however my ear piece speaker now rattles when i play music at medium levels. I have tried installing additional adhesive to it, but still cracks.
Tony Ho - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 16,183
