주요 콘텐츠로 건너뛰기
소개
This is the replacement guide for Sony Xperia Z3 Dual as well as Sony Xperia Z3 front camera.
  1. Sony Xperia Z3 Dual Front Camera Replacement, Front Camera: 1 단계, 이미지 1/1
    • Power off the phone and remove two SIM card trays before replacement.
  2. Sony Xperia Z3 Dual Front Camera Replacement: 2 단계, 이미지 1/3 Sony Xperia Z3 Dual Front Camera Replacement: 2 단계, 이미지 2/3 Sony Xperia Z3 Dual Front Camera Replacement: 2 단계, 이미지 3/3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker.
  3. Sony Xperia Z3 Dual Front Camera Replacement: 3 단계, 이미지 1/1
    • Remove back cover carefully and avoid cracking the glass.
  4. Sony Xperia Z3 Dual Front Camera Replacement: 4 단계, 이미지 1/3 Sony Xperia Z3 Dual Front Camera Replacement: 4 단계, 이미지 2/3 Sony Xperia Z3 Dual Front Camera Replacement: 4 단계, 이미지 3/3
    • Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement.
  5. Sony Xperia Z3 Dual Front Camera Replacement: 5 단계, 이미지 1/1
    • Remove screws at first.
  6. Sony Xperia Z3 Dual Front Camera Replacement: 6 단계, 이미지 1/3 Sony Xperia Z3 Dual Front Camera Replacement: 6 단계, 이미지 2/3 Sony Xperia Z3 Dual Front Camera Replacement: 6 단계, 이미지 3/3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Front Camera Replacement: 7 단계, 이미지 1/3 Sony Xperia Z3 Dual Front Camera Replacement: 7 단계, 이미지 2/3 Sony Xperia Z3 Dual Front Camera Replacement: 7 단계, 이미지 3/3
    • Release all the connectors connecting with motherboard.
    • Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful.
  8. Sony Xperia Z3 Dual Front Camera Replacement: 8 단계, 이미지 1/2 Sony Xperia Z3 Dual Front Camera Replacement: 8 단계, 이미지 2/2
    • Release the connector and pull out the flex at first, please be careful as you can.
    • Remove the front camera finally.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 2014년 03월 25일
43,609 평판
안내서 62개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 2,266
