주요 콘텐츠로 건너뛰기
소개
This is the replace guide for Sony Xperia Z3 Dual and Sony Xperia Z3 headphone jack. But your phone may be not waterproof after DIY headphone jack replacement.
  1. Sony Xperia Z3 Dual Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 1/1
    • Power off the phone and remove two SIM card trays before headphone jack replacement.
  2. Sony Xperia Z3 Dual Headphone Jack Replacement: 2 단계, 이미지 1/3 Sony Xperia Z3 Dual Headphone Jack Replacement: 2 단계, 이미지 2/3 Sony Xperia Z3 Dual Headphone Jack Replacement: 2 단계, 이미지 3/3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick.
    • Slide the guitar pick to cut the sticker all around every side.
  3. Sony Xperia Z3 Dual Headphone Jack Replacement: 3 단계, 이미지 1/1
    • Remove back cover.
  4. Sony Xperia Z3 Dual Headphone Jack Replacement: 4 단계, 이미지 1/3 Sony Xperia Z3 Dual Headphone Jack Replacement: 4 단계, 이미지 2/3 Sony Xperia Z3 Dual Headphone Jack Replacement: 4 단계, 이미지 3/3
    • Remove battery easily.
  5. Sony Xperia Z3 Dual Headphone Jack Replacement: 5 단계, 이미지 1/1
    • Twist off two screws by Philips screwdriver at first.
  6. Sony Xperia Z3 Dual Headphone Jack Replacement: 6 단계, 이미지 1/3 Sony Xperia Z3 Dual Headphone Jack Replacement: 6 단계, 이미지 2/3 Sony Xperia Z3 Dual Headphone Jack Replacement: 6 단계, 이미지 3/3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Headphone Jack Replacement: 7 단계, 이미지 1/3 Sony Xperia Z3 Dual Headphone Jack Replacement: 7 단계, 이미지 2/3 Sony Xperia Z3 Dual Headphone Jack Replacement: 7 단계, 이미지 3/3
    • Release all the connectors connecting with motherboard.
    • Pry it up from left side. Please be careful with some hidden keys, they held the motherboard really tightly.
  8. Sony Xperia Z3 Dual Headphone Jack Replacement: 8 단계, 이미지 1/2 Sony Xperia Z3 Dual Headphone Jack Replacement: 8 단계, 이미지 2/2
    • Remove securing cover beside headphone jack.
  9. Sony Xperia Z3 Dual Headphone Jack Replacement: 9 단계, 이미지 1/3 Sony Xperia Z3 Dual Headphone Jack Replacement: 9 단계, 이미지 2/3 Sony Xperia Z3 Dual Headphone Jack Replacement: 9 단계, 이미지 3/3
    • Remove the flex cover on the headphone jack. It's a part of the assembly and comes with denoise MIC and sensors.
    • Cut the adhesive sticker between headphone jack and midframe.
    • Remove headphone jack finally.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 2014년 03월 25일
43,609 평판
안내서 62개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 6,914
