주요 콘텐츠로 건너뛰기
Sony Xperia Z3 Dual LCD screen Replacement
필요한 것
동영상 개요
  1. Sony Xperia Z3 Dual LCD screen Replacement, LCD screen: 1 단계, 이미지 3개 중 1개 Sony Xperia Z3 Dual LCD screen Replacement, LCD screen: 1 단계, 이미지 3개 중 2개 Sony Xperia Z3 Dual LCD screen Replacement, LCD screen: 1 단계, 이미지 3개 중 3개
    • Use a heat gun to soften the back cover sticker around the edges.
    • Use a suction cup to pull open a gap and insert a guitar pick.
    • Carefully slide the guitar pick to cut the sticker. If you use too much force you can easily crack the glass!
  2. Sony Xperia Z3 Dual LCD screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the back cover and have a quick look around the inside.
  3. Sony Xperia Z3 Dual LCD screen Replacement: 3 단계, 이미지 3개 중 1개 Sony Xperia Z3 Dual LCD screen Replacement: 3 단계, 이미지 3개 중 2개 Sony Xperia Z3 Dual LCD screen Replacement: 3 단계, 이미지 3개 중 3개
    • Release the battery connector and peel the sticky tape from the bottom corner of the battery.
    • Use the sticky tape to carefully pull up and remove the battery.
  4. Sony Xperia Z3 Dual LCD screen Replacement: 4 단계, 이미지 1개 중 1개
    • The Sony Xperia Z3 Dual 3100mAh battery.
  5. Sony Xperia Z3 Dual LCD screen Replacement: 5 단계, 이미지 3개 중 1개 Sony Xperia Z3 Dual LCD screen Replacement: 5 단계, 이미지 3개 중 2개 Sony Xperia Z3 Dual LCD screen Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two screws with a Philips screwdriver.
    • Release the three connectors connected to the loudspeaker assembly.
    • Remove the vibrator securing bracket (this may be optional for some devices).
  6. Sony Xperia Z3 Dual LCD screen Replacement: 6 단계, 이미지 3개 중 1개 Sony Xperia Z3 Dual LCD screen Replacement: 6 단계, 이미지 3개 중 2개 Sony Xperia Z3 Dual LCD screen Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the loudspeaker assembly cover. Tip: pull it toward the centre of the phone as you pull upwards.
    • Pry up and remove the loudspeaker assembly.
    • Carefully loosen the microphone here.
  7. Sony Xperia Z3 Dual LCD screen Replacement: 7 단계, 이미지 3개 중 1개 Sony Xperia Z3 Dual LCD screen Replacement: 7 단계, 이미지 3개 중 2개 Sony Xperia Z3 Dual LCD screen Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully remove the metal LCD flex cover.
    • Release the LCD connector from the main flex cable.
    • Carefully pry the LCD connector from the sticker underneath.
  8. Sony Xperia Z3 Dual LCD screen Replacement: 8 단계, 이미지 2개 중 1개 Sony Xperia Z3 Dual LCD screen Replacement: 8 단계, 이미지 2개 중 2개
    • Removing the screen is the same as opening the back cover. Heat, open a gap, insert a guitar pick, slide and cut the sticker. Start from the top.
    • Tip: The glue here is stronger, you may need to insert something sharp in the corner to start.
  9. Sony Xperia Z3 Dual LCD screen Replacement: 9 단계, 이미지 3개 중 1개 Sony Xperia Z3 Dual LCD screen Replacement: 9 단계, 이미지 3개 중 2개 Sony Xperia Z3 Dual LCD screen Replacement: 9 단계, 이미지 3개 중 3개
    • You can use a plastic opening tool to cut the sticker of left and right side.
    • Finally Pull the screen up and remove it. Be careful with the bottom LCD connector and sticker.
  10. Sony Xperia Z3 Dual LCD screen Replacement, Kindly Remind: 10 단계, 이미지 2개 중 1개 Sony Xperia Z3 Dual LCD screen Replacement, Kindly Remind: 10 단계, 이미지 2개 중 2개
    • It's a weird design that the earpiece speaker is stuck onto the Sony Xperia Z3 front glass and not the supporting frame. It means it is possible to remove the LCD screen with the earpiece speaker attached, or separate the speaker from its securing bracket.
    • The above steps depend on the length of the guitar pick that you use.
결론
다른 64명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Sophia
회원 가입일: 03/25/14
43,905 평판
안내서 62개를 작성함
9가이드 댓글
Same procedure with the Z3?
Heljar Kjerstad - 답글
Am hasna,am live Tanzania.my phone broke touch screen and back cover screen .so what a get this tools
hasnerabdi - 답글
Please am in Ghana, how can i get a screen replacement and how much will it cost????
David Mensah - 답글
Z3 is slightly different at the bottom assembly marked row 4
Tony Shoreman - 답글
I purchased Sony z3 dual in San Francisco and the screen got broke were can I get new screen fix in India
Vaibhav Bhirud - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 69
전체 시간: 197,227
