주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This is the replace guide for Sony Xperia Z3 Dual as well as Z3 loudspeaker assembly.
동영상 개요
  1. Heat to soften back cover sticker. Place the suction cup and try to open a gap. Insert the guitar pick into the gap.
    • Heat to soften back cover sticker.
    • Place the suction cup and try to open a gap.
    • Insert the guitar pick into the gap.
  2. Slide the guitar pick to cut the sticker and remove the back cover. Slide the guitar pick to cut the sticker and remove the back cover.
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Remove two screws by Philips screwdriver. Release all the connectors connecting with loudspeaker assembly. Remove the small vibrator securing bracket.
    • Remove two screws by Philips screwdriver.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove the small vibrator securing bracket.
  4. Remove the securing cover. It's thin and weak, please be careful when remove it. Remove the securing cover. It's thin and weak, please be careful when remove it. Remove the securing cover. It's thin and weak, please be careful when remove it.
    • Remove the securing cover. It's thin and weak, please be careful when remove it.
  5. Pry up the assembly and carry it out. Pry up the assembly and carry it out. Pry up the assembly and carry it out.
    • Pry up the assembly and carry it out.
  6. Remove the loudspeaker assembly finally. Be careful with the flex beside assembly. Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
    • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 2014년 03월 25일
42,946 평판
안내서 62개 작성하였습니다
this is all good but is there a link to the part ?
morten hundevad - 답글
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 4,095
