주요 콘텐츠로 건너뛰기
Sony Xperia Z3 Dual Loudspeaker Assembly Replacement
필요한 것
동영상 개요
  1. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: 1 단계, 이미지 1/3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: 1 단계, 이미지 2/3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: 1 단계, 이미지 3/3
    • Heat to soften back cover sticker.
    • Place the suction cup and try to open a gap.
    • Insert the guitar pick into the gap.
  2. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 2 단계, 이미지 1/2 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 2 단계, 이미지 2/2
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 3 단계, 이미지 1/3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 3 단계, 이미지 2/3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 3 단계, 이미지 3/3
    • Remove two screws by Philips screwdriver.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove the small vibrator securing bracket.
  4. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 4 단계, 이미지 1/3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 4 단계, 이미지 2/3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 4 단계, 이미지 3/3
    • Remove the securing cover. It's thin and weak, please be careful when remove it.
  5. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 5 단계, 이미지 1/3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 5 단계, 이미지 2/3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 5 단계, 이미지 3/3
    • Pry up the assembly and carry it out.
  6. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 6 단계, 이미지 1/2 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: 6 단계, 이미지 2/2
    • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 2개
this is all good but is there a link to the part ?
morten hundevad - 답글
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 11
전체 시간: 4,405
