주요 콘텐츠로 건너뛰기
Sony Xperia Z3 Dual Main flex Replacement
필요한 것
  1. Sony Xperia Z3 Dual Main flex Replacement, Main flex: 1 단계, 이미지 1/2 Sony Xperia Z3 Dual Main flex Replacement, Main flex: 1 단계, 이미지 2/2
    • Heat to soften back cover sticker.
    • Place suction cup and pull open a gap.
  2. Sony Xperia Z3 Dual Main flex Replacement: 2 단계, 이미지 1/3 Sony Xperia Z3 Dual Main flex Replacement: 2 단계, 이미지 2/3 Sony Xperia Z3 Dual Main flex Replacement: 2 단계, 이미지 3/3
    • Insert into guitar pick, slide and cut the sticker. Finally, remove the back cover.
  3. Sony Xperia Z3 Dual Main flex Replacement: 3 단계, 이미지 1/3 Sony Xperia Z3 Dual Main flex Replacement: 3 단계, 이미지 2/3 Sony Xperia Z3 Dual Main flex Replacement: 3 단계, 이미지 3/3
    • Remove the battery.
  4. Sony Xperia Z3 Dual Main flex Replacement: 4 단계, 이미지 1/3 Sony Xperia Z3 Dual Main flex Replacement: 4 단계, 이미지 2/3 Sony Xperia Z3 Dual Main flex Replacement: 4 단계, 이미지 3/3
    • Twist off two screws here.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove vibrator securing bracket.
  5. Sony Xperia Z3 Dual Main flex Replacement: 5 단계, 이미지 1/2 Sony Xperia Z3 Dual Main flex Replacement: 5 단계, 이미지 2/2
    • Remove loudspeaker assembly cover and assembly itself.
  6. Sony Xperia Z3 Dual Main flex Replacement: 6 단계, 이미지 1/3 Sony Xperia Z3 Dual Main flex Replacement: 6 단계, 이미지 2/3 Sony Xperia Z3 Dual Main flex Replacement: 6 단계, 이미지 3/3
    • Pry up the MIC. It's a part of the main flex.
    • Release the connector with LCD screen flex and the connector with motherboard.
  7. Sony Xperia Z3 Dual Main flex Replacement: 7 단계, 이미지 1/3 Sony Xperia Z3 Dual Main flex Replacement: 7 단계, 이미지 2/3 Sony Xperia Z3 Dual Main flex Replacement: 7 단계, 이미지 3/3
    • Push the upper power button & volume button flex branch bracket as the direction marked, and then remove it easily.
    • Pry up the lower shutter button flex branch bracket carefully. It's different from the upper one, it's come with the flex together but the upper one not.
  8. Sony Xperia Z3 Dual Main flex Replacement: 8 단계, 이미지 1/3 Sony Xperia Z3 Dual Main flex Replacement: 8 단계, 이미지 2/3 Sony Xperia Z3 Dual Main flex Replacement: 8 단계, 이미지 3/3
    • Get the flex from the sticker underneath carefully.
    • And then, take the power button & volume button flex branch out from the slot.
    • Finally, remove the whole main flex.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 4개
Hello
I changed my power, but I felt the power button action do you think the problem of what can be
Thanks
mehdi ghanbarian - 답글
Is it ok to remove the small copper stickers under the flex?
Miguel Damayo - 답글
اريد المنتج هذا
H ammody - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 9,796
