주요 콘텐츠로 건너뛰기
Sony Xperia Z3 USB cover and SD card slot cover Replacement
동영상 개요
Sony Xperia Z3 USB Port Cover + SD/SIM Flap Replacement
  1. Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: 1 단계, 이미지 1/3 Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: 1 단계, 이미지 2/3 Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: 1 단계, 이미지 3/3
    • Use your fingers to pull firmly on the broken USB port cover until it pops out.
    • Remove the USB port cover.
  2. Sony Xperia Z3 USB cover and SD card slot cover Replacement: 2 단계, 이미지 1/3 Sony Xperia Z3 USB cover and SD card slot cover Replacement: 2 단계, 이미지 2/3 Sony Xperia Z3 USB cover and SD card slot cover Replacement: 2 단계, 이미지 3/3
    • Use your fingers to firmly pull out the SD/SIM card flap.
    • Remove the SD/SIM card flap.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,783 평판
안내서 62개 작성하였습니다
댓글 4개
Does Z3 and Z3V have same size USB flaps?
Sudip Shrestha - 답글
i need for model D6633
Umer Farooq -
ineed both same size
Umer Farooq -
Part of the white plastic end connected to the old USB charge port cover flap on my Sony XperiaZ3v is still inside my phone. How do I get that broken piece out of the phone before installing the new USB cover in the phone?
Narda Dawidowicz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 20,941
