주요 콘텐츠로 건너뛰기
Sony Xperia Z5 Charging Port Flex Replacement
필요한 것
  1. Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: 1 단계, 이미지 1/2 Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: 1 단계, 이미지 2/2
    • Remove SIM card tray.
  2. Sony Xperia Z5 Charging Port Flex Replacement: 2 단계, 이미지 1/2 Sony Xperia Z5 Charging Port Flex Replacement: 2 단계, 이미지 2/2
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and inert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 Charging Port Flex Replacement: 3 단계, 이미지 1/3 Sony Xperia Z5 Charging Port Flex Replacement: 3 단계, 이미지 2/3 Sony Xperia Z5 Charging Port Flex Replacement: 3 단계, 이미지 3/3
    • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
    • Remove back cover.
  4. Sony Xperia Z5 Charging Port Flex Replacement: 4 단계, 이미지 1/3 Sony Xperia Z5 Charging Port Flex Replacement: 4 단계, 이미지 2/3 Sony Xperia Z5 Charging Port Flex Replacement: 4 단계, 이미지 3/3
    • Release battery connector and pull off the adhesive tape underneath.
    • Pry up battery.
  5. Sony Xperia Z5 Charging Port Flex Replacement: 5 단계, 이미지 1/3 Sony Xperia Z5 Charging Port Flex Replacement: 5 단계, 이미지 2/3 Sony Xperia Z5 Charging Port Flex Replacement: 5 단계, 이미지 3/3
    • Release rear camera connector, front camera connector, audio jack flex connector and main flex connector on the motherboard and remove the screws there.
    • Take away the plastic bracket.
  6. Sony Xperia Z5 Charging Port Flex Replacement: 6 단계, 이미지 1/3 Sony Xperia Z5 Charging Port Flex Replacement: 6 단계, 이미지 2/3 Sony Xperia Z5 Charging Port Flex Replacement: 6 단계, 이미지 3/3
    • Remove metal cover securing loudspeaker and twist off screws.
    • Pry up and loosen the bottom side of main flex assembly.
  7. Sony Xperia Z5 Charging Port Flex Replacement: 7 단계, 이미지 1/2 Sony Xperia Z5 Charging Port Flex Replacement: 7 단계, 이미지 2/2
    • Remove main flex. ( Attention: the fingerprint sensor connector is here, be careful to loosen it)
  8. Sony Xperia Z5 Charging Port Flex Replacement: 8 단계, 이미지 1/2 Sony Xperia Z5 Charging Port Flex Replacement: 8 단계, 이미지 2/2
    • This is main flex assembly. (It comes with loudspeaker and vibration motor )
  9. Sony Xperia Z5 Charging Port Flex Replacement: 9 단계, 이미지 1/2 Sony Xperia Z5 Charging Port Flex Replacement: 9 단계, 이미지 2/2
    • Remove rear camera.
  10. Sony Xperia Z5 Charging Port Flex Replacement: 10 단계, 이미지 1/3 Sony Xperia Z5 Charging Port Flex Replacement: 10 단계, 이미지 2/3 Sony Xperia Z5 Charging Port Flex Replacement: 10 단계, 이미지 3/3
    • Remove that securing bracket, then remove front camera.
  11. Sony Xperia Z5 Charging Port Flex Replacement: 11 단계, 이미지 1/3 Sony Xperia Z5 Charging Port Flex Replacement: 11 단계, 이미지 2/3 Sony Xperia Z5 Charging Port Flex Replacement: 11 단계, 이미지 3/3
    • Release connectors on the motherboard. Remove motherboard.
  12. Sony Xperia Z5 Charging Port Flex Replacement: 12 단계, 이미지 1/3 Sony Xperia Z5 Charging Port Flex Replacement: 12 단계, 이미지 2/3 Sony Xperia Z5 Charging Port Flex Replacement: 12 단계, 이미지 3/3
    • Remove charging port flex.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Lenka
회원 가입일: 11/06/15
2,384 평판
안내서 6개 작성하였습니다
댓글 3개
How about the waterproof adhesive ?
Tess - 답글
Would you have a step by step method to replace it ?
Tess - 답글
I can’t turn my phone back on. Any clues?
Bjoern Aeschlimann - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 16
전체 시간: 17,558
