주요 콘텐츠로 건너뛰기
Sony Xperia Z5 Compact Battery Replacement
필요한 것
  1. Sony Xperia Z5 Compact Battery Replacement, Battery: 1 단계, 이미지 1/2 Sony Xperia Z5 Compact Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5 Compact Battery Replacement: 2 단계, 이미지 1/3 Sony Xperia Z5 Compact Battery Replacement: 2 단계, 이미지 2/3 Sony Xperia Z5 Compact Battery Replacement: 2 단계, 이미지 3/3
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5 Compact Battery Replacement: 3 단계, 이미지 1/2 Sony Xperia Z5 Compact Battery Replacement: 3 단계, 이미지 2/2
    • Twist off 10 Phillips screws all.
    • Loosen NFC clip and flashlight clip.
  4. Sony Xperia Z5 Compact Battery Replacement: 4 단계, 이미지 1/3 Sony Xperia Z5 Compact Battery Replacement: 4 단계, 이미지 2/3 Sony Xperia Z5 Compact Battery Replacement: 4 단계, 이미지 3/3
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5 Compact Battery Replacement: 5 단계, 이미지 1/3 Sony Xperia Z5 Compact Battery Replacement: 5 단계, 이미지 2/3 Sony Xperia Z5 Compact Battery Replacement: 5 단계, 이미지 3/3
    • Remove front camera.
  6. Sony Xperia Z5 Compact Battery Replacement: 6 단계, 이미지 1/3 Sony Xperia Z5 Compact Battery Replacement: 6 단계, 이미지 2/3 Sony Xperia Z5 Compact Battery Replacement: 6 단계, 이미지 3/3
    • Remove rear camera.
  7. Sony Xperia Z5 Compact Battery Replacement: 7 단계, 이미지 1/3 Sony Xperia Z5 Compact Battery Replacement: 7 단계, 이미지 2/3 Sony Xperia Z5 Compact Battery Replacement: 7 단계, 이미지 3/3
    • Remove loudspeaker.
  8. Sony Xperia Z5 Compact Battery Replacement: 8 단계, 이미지 1/3 Sony Xperia Z5 Compact Battery Replacement: 8 단계, 이미지 2/3 Sony Xperia Z5 Compact Battery Replacement: 8 단계, 이미지 3/3
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
  9. Sony Xperia Z5 Compact Battery Replacement: 9 단계, 이미지 1/3 Sony Xperia Z5 Compact Battery Replacement: 9 단계, 이미지 2/3 Sony Xperia Z5 Compact Battery Replacement: 9 단계, 이미지 3/3
    • Push audio jack out of the slot, no adhesive underneath.
    • Release LCD flex connector and main flex connector. Use a small flat tool to flip up the white edge of the connector to release tension on the end of the flex cable. Then the flex cable should slide out without any resistance.
    • Separate motherboard assembly from middle housing.
    ATTENTION: At the edge of the board (top left beside the battery, see picture 3 in step 8) there are two small contact springs connected to an internal board layer (probably the antenna connection). When loosening the flex cables, these contacts can rub against the edge of the housing - in my case, they were torn off afterwards and lay loose on my work surface.
    Friedbert Widmann - 답글
  10. Sony Xperia Z5 Compact Battery Replacement: 10 단계, 이미지 1/2 Sony Xperia Z5 Compact Battery Replacement: 10 단계, 이미지 2/2
    • Take away NFC antenna on battery.
    • Be aware that the NFC antenna is held by an adhesive and made of thin plastic. Remove it very carefully.
  11. Sony Xperia Z5 Compact Battery Replacement: 11 단계, 이미지 1/3 Sony Xperia Z5 Compact Battery Replacement: 11 단계, 이미지 2/3 Sony Xperia Z5 Compact Battery Replacement: 11 단계, 이미지 3/3
    • Release battery connector.
    • Pull straight out on the black ends of the battery adhesive strips until they come off.
    • Pry up and remove battery.
    Mark the position of the battery with a fine pencil, as the new battery must be placed exactly in the same position (tolerance: approx. 0.5 mm).
  12. Sony Xperia Z5 Compact Battery Replacement: 12 단계, 이미지 1/2 Sony Xperia Z5 Compact Battery Replacement: 12 단계, 이미지 2/2
    • Place the new battery adhesive strips on the motherboard
    • Press the new battery in place
    • Follow all the steps in reverse to reassemble your phone
    As of Jan 2018, the battery adhesive strips are not in the parts list above. (Maybe they were at one time, but are no longer available?) I used some very small 3M Command hook adhesive strips instead.
    MR66 - 답글
    As of Sep 2021, the battery adhesive strips are still not in the parts list. I also had to source my own battery adhesives in the middle of the repair.
    Mike Austin - 답글
결론
다른 26명이 해당 안내서를 완성하였습니다.
Witrigs
회원 가입일: 11/24/15
69,454 평판
안내서 378개 작성하였습니다
댓글 18개
Will the device boot up with no error message after replacing it with new battery? Or do you need some programming before or after replacing it?
Christian Duane Co - 답글
There is no error when battery is changed.
Just successfully changed my battery without any issue. Booted up normally and able to do everything I was able to do before.
Thank you for the awesome guide :)
DANIEL SOESILO -
The Sony Experia Z5 Compact is water and dust proof. Will heating the back after putting it back on reseal the phone - or is there another step that needs to be added?
Steven Cox - 답글
You can watch the repair video on youtube: https://www.youtube.com/user/lagaiPhoneS..., but I fixed it here https://lagaiphone.se/shop/sony-z5-compa... they used the adhesive but no water resistant warranty after repair. so far so good!
LagaiPhone -
Pretty annoying, this mentions NOTHING about the battery adhesive strips to order separately, and neither of the “things to buy” come with them. I just replaced my battery, but it’s just flopping around inside at the moment. Where do I order the battery adhesive strips to adhere the battery to the motherboard? Note for others doing this too, you NEED the adhesive strips separately beside the battery and the back adhesive!
michael - 답글
Yeah I ran into the same issue, I found them at https://www.teknikdelar.se/mobilreservde... but that's a Swedish company I think. I made a suggested edit to this post, suggesting the need for strips to be at least mentioned but I got a reply of “just use some tape".
See Hy -
I bought some adhesive strips (there are plenty of them for the iPhone 6/7/8) and cut them with scissors.
Friedbert Widmann -
It doesn't work for me. Connected the battery as it was and can't get it started and now I'm screwed. Such a waste.. What could possibly be wrong?
Morgan Westerlund - 답글
Thanks so much for this guide… and people who have commented for extra tips like the battery strips!
Phone booted up perfectly and everything seems to be working. Thrilled that I should have some extra time with my phone before having to get a new one.
All in spent around £10 - Took me about 2 hours to do but I’ve never done anything like this before and some things took me a bit longer to figure out. (I only got one adhesive strip though there are two in there, one seems to be holding okay though.)
I wrote some additional comments for the steps here to help anyone who like me is new to this. (Wasn’t enough characters to do it here.)
https://charana-notes.blogspot.com/2018/...
Charlotte - 답글
Oh I should have read your comments about the flex cable connectors. :+1:
per.tautorat -
Thank you for this guide, everything worked good for me. I replaced the Camera module and USB connector too,
But I am missing one thing in this manual. How to reconnect the flexcables for lcd and mainboard properly? Is there any special trick, i am really thankful that I somehow not destroyed the cable, nor the connector. But I think I was kind of lucky…
per.tautorat - 답글
Very nice guide!!!
Two things that weren’t immediately clear to me, so maybe useful for others as well:
- Step 2: the back cover is only glued at the edges
- Step 9: the white part of the main and LCD flex connectors turns upwards to unlock it
Stijn Debruyckere - 답글
I followed everything, and the battery seems to work. A few tips on step 9 would be great, though. But now the display is not showing anything. But it seems the touchscreen still works, I get sounds and vibrations when I press on the parts where the numpad use to be for the decryption of the hard drive. Any Idea on how I could bring this to a full success?
palipalo9 - 답글
I undertook the battery replacement and put a new charge port in while I was at it.
After putting the phone all back together and powered it up everything appears to work on the screen functions but the phone no longer reads the SIM card or recognises my WIFI. This has rendered the phone unusable. I have tested the SIM in another phone and it is OK. The phone recognises the SIM and does a restart but then does not read the SIM card once it has restarted and displays the message “No SIM card - Emergency calls only”. It is as if the SIM card reader is not working.
I spoke to a technician and he said he wears a wrist band with a wire connected a metal earth to eliminate static electricity in his body going through the phone and short circuiting it causing damage. Could this possibly what has happened to my phone as there was no mention about having the earth yourself while undertaking the battery replacement.
Does anyone have an explanation or solution to my SIM card not reading?
Jason - 답글
An update on my last post. I managed to get my phone to connect to WiFi but I had to be right next to my modem to get a strong enough signal. Could this mean an aerial problem?
Jason - 답글
I followed these instructions and managed to complete the replacement with (almost) 100% success. I would however say that most of the disassembly was unnecessary and in my case caused the small problem - namely a bright white spot on the screen probably due to excessive wrestling. It seems to me that nothing beyond the back bracket needs to be removed - everything else can stay and certainly the motherboard. My phone did not have the black adhesive strips mentioned in Step 11 and even if they were there I don’t see why so much disassembly is required.
Take the NFC and back bracket off and pry the battery of the motherboard slowly and carefully. That’s about it!
Brian Westhead - 답글
The guide seems to work great. In addition to the battery, I changed the charging port and re-attached the screen which had detached from one edge of the frame. There was one problem: I couldn’t remove the battery at all. I tried to carefully pull the adhesive strips from under the battery, but both of them just snapped right in the beginning. I think they might have become brittle over time, because I tried to be really careful and pull them straight. I gently tried to pry the battery off, but that would’ve required too much force. Any tips for this situation? Would some heat help? Or should I try and slide something under the battery and saw the adhesive strips off? Any help would be greatly appreciated!
Antti - 답글
I successfully followed this guide to replace the battery in my Xperia Z5 Compact. The only problem I ran into was the old battery strip snapping when I tried pulling it out. I had to use a heat gun to soften up the old adhesive strip to remove the old battery. The parts list is missing adhesive for the replacement battery, so make sure you have a suitable way to affix the replacement battery to the board. Everything went back together smoothly, and the phone is fully functional. Being completely inexperienced with phone repair, it took me about 90 minutes to complete this guide.
Mike Austin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 43
30일 전: 162
전체 시간: 72,742
