이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
While your Sony Xperia Z5 Compact battery drains quickly after long period of use, you can follow this guide to replace the battery yourself.
필요한 것
Push audio jack out of the slot, no adhesive underneath.
Release LCD flex connector and main flex connector. Use a small flat tool to flip up the white edge of the connector to release tension on the end of the flex cable. Then the flex cable should slide out without any resistance.
Separate motherboard assembly from middle housing.
다른 26명이 해당 안내서를 완성하였습니다.
댓글 18개
Will the device boot up with no error message after replacing it with new battery? Or do you need some programming before or after replacing it?
There is no error when battery is changed.
Just successfully changed my battery without any issue. Booted up normally and able to do everything I was able to do before.
Thank you for the awesome guide :)
The Sony Experia Z5 Compact is water and dust proof. Will heating the back after putting it back on reseal the phone - or is there another step that needs to be added?
Steven Cox - 답글
You can watch the repair video on youtube: https://www.youtube.com/user/lagaiPhoneS..., but I fixed it here https://lagaiphone.se/shop/sony-z5-compa... they used the adhesive but no water resistant warranty after repair. so far so good!
Pretty annoying, this mentions NOTHING about the battery adhesive strips to order separately, and neither of the “things to buy” come with them. I just replaced my battery, but it’s just flopping around inside at the moment. Where do I order the battery adhesive strips to adhere the battery to the motherboard? Note for others doing this too, you NEED the adhesive strips separately beside the battery and the back adhesive!
