주요 콘텐츠로 건너뛰기
Sony Xperia Z5 Compact Motherboard Replacement
필요한 것
  1. Sony Xperia Z5 Compact Motherboard Replacement, Charging port flex: 1 단계, 이미지 1/2 Sony Xperia Z5 Compact Motherboard Replacement, Charging port flex: 1 단계, 이미지 2/2
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5 Compact Motherboard Replacement: 2 단계, 이미지 1/3 Sony Xperia Z5 Compact Motherboard Replacement: 2 단계, 이미지 2/3 Sony Xperia Z5 Compact Motherboard Replacement: 2 단계, 이미지 3/3
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5 Compact Motherboard Replacement: 3 단계, 이미지 1/2 Sony Xperia Z5 Compact Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove all 10 Phillips screws.
    • Disconnect NFC clip and flashlight clip.
  4. Sony Xperia Z5 Compact Motherboard Replacement: 4 단계, 이미지 1/3 Sony Xperia Z5 Compact Motherboard Replacement: 4 단계, 이미지 2/3 Sony Xperia Z5 Compact Motherboard Replacement: 4 단계, 이미지 3/3
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5 Compact Motherboard Replacement: 5 단계, 이미지 1/3 Sony Xperia Z5 Compact Motherboard Replacement: 5 단계, 이미지 2/3 Sony Xperia Z5 Compact Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove front camera.
  6. Sony Xperia Z5 Compact Motherboard Replacement: 6 단계, 이미지 1/3 Sony Xperia Z5 Compact Motherboard Replacement: 6 단계, 이미지 2/3 Sony Xperia Z5 Compact Motherboard Replacement: 6 단계, 이미지 3/3
    • Remove rear camera.
  7. Sony Xperia Z5 Compact Motherboard Replacement: 7 단계, 이미지 1/3 Sony Xperia Z5 Compact Motherboard Replacement: 7 단계, 이미지 2/3 Sony Xperia Z5 Compact Motherboard Replacement: 7 단계, 이미지 3/3
    • Remove loudspeaker.
  8. Sony Xperia Z5 Compact Motherboard Replacement: 8 단계, 이미지 1/3 Sony Xperia Z5 Compact Motherboard Replacement: 8 단계, 이미지 2/3 Sony Xperia Z5 Compact Motherboard Replacement: 8 단계, 이미지 3/3
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
  9. Sony Xperia Z5 Compact Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove charging port flex.
  10. Sony Xperia Z5 Compact Motherboard Replacement, Motherboard: 10 단계, 이미지 1/2 Sony Xperia Z5 Compact Motherboard Replacement, Motherboard: 10 단계, 이미지 2/2
    • Remove the motherboard/battery assembly.
    • Using a spudger, release the battery connector from the motherboard.
  11. Sony Xperia Z5 Compact Motherboard Replacement: 11 단계, 이미지 1/2 Sony Xperia Z5 Compact Motherboard Replacement: 11 단계, 이미지 2/2
    • Slowly pull out the two battery tapes located on the right side of the battery.
    • Remove the battery from the motherboard.
  12. Sony Xperia Z5 Compact Motherboard Replacement: 12 단계, 이미지 1/2 Sony Xperia Z5 Compact Motherboard Replacement: 12 단계, 이미지 2/2
    • Place two pieces of binding tape on the center of the motherboard.
    • Reattach the battery to the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Grant Conner
회원 가입일: 02/20/20
280 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 1,167
