주요 콘텐츠로 건너뛰기
Sony Xperia Z5 LCD Screen Replacement
필요한 것
동영상 개요
  1. Sony Xperia Z5 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/2 Sony Xperia Z5 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/2
    • Remove SIM card tray.
  2. Sony Xperia Z5 LCD Screen Replacement: 2 단계, 이미지 1/2 Sony Xperia Z5 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and insert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 LCD Screen Replacement: 3 단계, 이미지 1/3 Sony Xperia Z5 LCD Screen Replacement: 3 단계, 이미지 2/3 Sony Xperia Z5 LCD Screen Replacement: 3 단계, 이미지 3/3
    • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
    • Remove back cover.
  4. Sony Xperia Z5 LCD Screen Replacement: 4 단계, 이미지 1/3 Sony Xperia Z5 LCD Screen Replacement: 4 단계, 이미지 2/3 Sony Xperia Z5 LCD Screen Replacement: 4 단계, 이미지 3/3
    • Release battery connector.
    • Pull off the adhesive tape underneath the battery.
    • Pry up battery.
  5. Sony Xperia Z5 LCD Screen Replacement: 5 단계, 이미지 1/3 Sony Xperia Z5 LCD Screen Replacement: 5 단계, 이미지 2/3 Sony Xperia Z5 LCD Screen Replacement: 5 단계, 이미지 3/3
    • Release rear camera connector, front camera connector, audio jack connector and main flex connector on the motherboard.
    • Twist off screws there.
    • Remove that rubber securing bracket.
  6. Sony Xperia Z5 LCD Screen Replacement: 6 단계, 이미지 1/3 Sony Xperia Z5 LCD Screen Replacement: 6 단계, 이미지 2/3 Sony Xperia Z5 LCD Screen Replacement: 6 단계, 이미지 3/3
    • Remove metal cover and twist off two screws.
    • Loosen the bottom side of main flex assembly.
  7. Sony Xperia Z5 LCD Screen Replacement: 7 단계, 이미지 1/3 Sony Xperia Z5 LCD Screen Replacement: 7 단계, 이미지 2/3 Sony Xperia Z5 LCD Screen Replacement: 7 단계, 이미지 3/3
    • Loosen side button contactors ( Attention: the fingerprint sensor is here, be careful to loosen it), then remove the whole main flex assembly.
  8. Sony Xperia Z5 LCD Screen Replacement: 8 단계, 이미지 1/3 Sony Xperia Z5 LCD Screen Replacement: 8 단계, 이미지 2/3 Sony Xperia Z5 LCD Screen Replacement: 8 단계, 이미지 3/3
    • Remove rear camera.
    • Remove that securing bracket, then remove front camera.
  9. Sony Xperia Z5 LCD Screen Replacement: 9 단계, 이미지 1/3 Sony Xperia Z5 LCD Screen Replacement: 9 단계, 이미지 2/3 Sony Xperia Z5 LCD Screen Replacement: 9 단계, 이미지 3/3
    • Release LCD screen flex connector, charging port connector, microphone connector here.
    • Remove motherboard.
  10. Sony Xperia Z5 LCD Screen Replacement: 10 단계, 이미지 1/2 Sony Xperia Z5 LCD Screen Replacement: 10 단계, 이미지 2/2
    • Remove charging port flex.
  11. Sony Xperia Z5 LCD Screen Replacement: 11 단계, 이미지 1/2 Sony Xperia Z5 LCD Screen Replacement: 11 단계, 이미지 2/2
    • Remove microphone.
  12. Sony Xperia Z5 LCD Screen Replacement: 12 단계, 이미지 1/2 Sony Xperia Z5 LCD Screen Replacement: 12 단계, 이미지 2/2
    • Remove the metal bracket covering on the LCD screen flex.
  13. Sony Xperia Z5 LCD Screen Replacement: 13 단계, 이미지 1/3 Sony Xperia Z5 LCD Screen Replacement: 13 단계, 이미지 2/3 Sony Xperia Z5 LCD Screen Replacement: 13 단계, 이미지 3/3
    • The sticker underneath is strong, so use heat gun to soften it for a few minutes.
    • Remove LCD screen carefully.
    • Take extra care when prying along the bottom edge of the display to avoid damaging the display cable.
  14. Sony Xperia Z5 LCD Screen Replacement: 14 단계, 이미지 1/1
    • Done.
결론
다른 46명이 해당 안내서를 완성하였습니다.
Lenka
회원 가입일: 11/06/15
2,384 평판
안내서 6개 작성하였습니다
댓글 45개
Awesome guide. Helped me alot. However i got blank screen after installing the new screen. Dont panic. You must replace the tape that covers the lcd filters. If you dont the metal plate will bridge the connections and the LCD will not display. I thought i broke the LCD however just replaced the tape off the original LCD and BOOM!
Kiwi phone repairs - 답글
What are the filters? I have a repair shop and all screens are like these. Can't find them anywhere.
Johnny -
Hi, you need to reuse the black tape sticked on the original flex cable to cover the filters on the replacement part.
Adrien Ould Madi -
I would like also to know which tape you replaced.
Patrick -
What r the lcd filters as I have replaced a screen on Sony z5 on 2 phones now and the backlight isn't working on both phones but u can see that the screens r working any help would be great thanks
Barry -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 26
30일 전: 81
전체 시간: 97,676
