주요 콘텐츠로 건너뛰기
Sony Xperia go Front Glass/Digitizer Replacement
필요한 것
  1. Sony Xperia go Front Glass/Digitizer Replacement, Front Glass/Digitizer: 1 단계, 이미지 1/1
    • Show here is a Sony xperia go with broken glass digitizer.
  2. Sony Xperia go Front Glass/Digitizer Replacement: 2 단계, 이미지 1/3 Sony Xperia go Front Glass/Digitizer Replacement: 2 단계, 이미지 2/3 Sony Xperia go Front Glass/Digitizer Replacement: 2 단계, 이미지 3/3
    • Remove backcover, and remove all screws.
    • 1 Torx screw
    • 7 star screws (don't know their name)
    • Note some of the screws have rubber spacers, use caution to avoid breaking them. (See second Picture in this step)
    • Remove sim card tray. (See third picture)
    4 screw has rubber spacer, not 2 :-)
    paacohu - 답글
    Edited text to some instead of two, as the number varies
    lassedollerup - 답글
  3. Sony Xperia go Front Glass/Digitizer Replacement: 3 단계, 이미지 1/3 Sony Xperia go Front Glass/Digitizer Replacement: 3 단계, 이미지 2/3 Sony Xperia go Front Glass/Digitizer Replacement: 3 단계, 이미지 3/3
    • Now the front can be seperated from the back.
    • CAUTION! there are some doublesided tape blocks situated on top of the connectors to the digitizer.
    • Use spudger to seperate these carefully from eachother.
    • Now you can open the phone sideways. Once opened, please disconnect the battery, marked on third Picture with a yellow circle.
    • Now you can disconnect digitizer cable and screen cable, marked with red circles on third picture.
    • Now you will be able to remove the front from the back of the phone.
  4. Sony Xperia go Front Glass/Digitizer Replacement: 4 단계, 이미지 1/2 Sony Xperia go Front Glass/Digitizer Replacement: 4 단계, 이미지 2/2
    • Using a heat gun, heat around the edges and seperate the glass from the front cover. Work from bottom up.
    • Note the digitizer cable runs through a small hole behind the lcd, in the top of the phone.
    • When the glass is seperated, carefully lift the lcd a bit, to get the digitizer cable through the hole.
    • To protect the lcd from residue and fingerprints, cover it with masking tape, until you are ready to seal the glass to the cover.
    • When you have prepared new adhesive tape and the digitizer cable has been pulled through the hole to the backside of the phone.
    • Remove the masking tape from the lcd, and using some canned air, blow away dust and close the glass cover.
    • Finally reverse the disassembly and enjoy.
    What kind of adhesive to use to stick back the screen onto the phone?
    nerdyutet - 답글
    I use 3m doublesided adhesive tape. You can buy them in rolls at cut them to fit.
    lassedollerup - 답글
    It is also necessary to transfer a small foam spacer stuck around the frame of the digitizer from your old digitizer to the new one. There is also a plastic tab on at the bottom that should be transferred. Please notice this.
    Joszue - 답글
결론
다른 22명이 해당 안내서를 완성하였습니다.
lassedollerup
회원 가입일: 03/31/13
620 평판
안내서 1개 작성함
댓글 10개
can u make guide for installing loudspeaker please
anep tg - 답글
Nice guide but, I only want to change front cover and back cover, because it´s damaged . If Open my xperia go, I will lost water proof and dust proof?
Juliano - 답글
Hello sorry for my late reply.
I haven't had the chance to replace the loudspeaker, but earpiece is a square block, that you can pry out and replace, after you have seperated the front from the back.
lassedollerup - 답글
Dissasembly will most likely break waterproof. Haven't tested.
lassedollerup - 답글
Nice guide and easy to follow. Thank you.
alex jesty - 답글
I followed your guide to replace the digitizer, problem is , after i replaced it, my phone wont turn on....any help?
navin117 - 답글
Only advice is to open it again, and verify that all connectors are connected. Try bootĩng with charger plugged in.
lassedollerup -
Hi - super guide. I have replaced my digitizer no problem.
It wasn't all plain sailing though. I made a mistake (as a newbie) that I think might help others.
1: Before reassembly I wanted to check that the new digitizer would work. Very carefully I plugged the battery, lcd and digitizer back in and tried to boot up the phone. The parts weren't reassembled, simply arrange so I could get all the cables in.
On boot up the phone got stuck on the Sony screen. I assumed I'd somehow caught the phone in flash mode or something. This put me into a bit of a spin.
However, when I actually reassembled the phone it was fine - it booted up as normal. Perhaps their is a sensor somewhere that means the digitizer has to be over the lcd before the phone will work. Anyway. All sorted now thanks for the guide!
Ben - 답글
What kind of adhesive needed to seal back the screen onto the phone?
nerdyutet - 답글
Great guide - worked fine for me!
Lars Ove Kvalbein - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 40,110
