주요 콘텐츠로 건너뛰기
Sony Xplod CDX-MP30 CD Drive Motherboard Replacement
필요한 것
  1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Front Panel: 1 단계, 이미지 1/3 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Front Panel: 1 단계, 이미지 2/3 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Front Panel: 1 단계, 이미지 3/3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Main Panels: 2 단계, 이미지 1/2 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Main Panels: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Phillips #0 Screwdriver
    $5.49
    구매
  3. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 3 단계, 이미지 1/3 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 3 단계, 이미지 2/3 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Phillips #1 Screwdriver
    $5.49
    구매
    • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
    • Remove side-metal plates gently.
    • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
  4. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the black front plate of the stereo.
  5. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 5 단계, 이미지 1/2 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    $5.49
    구매
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
    • Lift off the top plate.
  6. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 6 단계, 이미지 1/3 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 6 단계, 이미지 2/3 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    $5.49
    구매
    • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
  7. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 7 단계, 이미지 1/3 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 7 단계, 이미지 2/3 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 7 단계, 이미지 3/3
    • Carefully pull the fuse out of the back of the stereo.
  8. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 8 단계, 이미지 1/2 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 8 단계, 이미지 2/2
    • Firmly grip the body of the stereo and pull off the silver back plate.
  9. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    $5.49
    구매
  10. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 10 단계, 이미지 1/2 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    $5.49
    구매
    • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
  11. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 11 단계, 이미지 1/3 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 11 단계, 이미지 2/3 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: 11 단계, 이미지 3/3
    • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
    • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
  12. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, CD Drive Motherboard: 12 단계, 이미지 1/1
    • The CD Drive Motherboard is located on the under-side of the CD Drive itself.
    • Please refer to the iFixit soldering guide to remove the CD Drive Motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Johnson
회원 가입일: 10/10/11
87 평판
안내서 1개 작성함
Cal Poly, Team 5-35, Amido Fall 2011 Cal Poly, Team 5-35, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G35
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 3,219
