주요 콘텐츠로 건너뛰기
Sony Xplod CDX-MP30 Jammed CD Replacement
필요한 것
  1. Sony Xplod CDX-MP30 Jammed CD Replacement, Front Panel: 1 단계, 이미지 1/3 Sony Xplod CDX-MP30 Jammed CD Replacement, Front Panel: 1 단계, 이미지 2/3 Sony Xplod CDX-MP30 Jammed CD Replacement, Front Panel: 1 단계, 이미지 3/3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Jammed CD Replacement, Main Panels: 2 단계, 이미지 1/2 Sony Xplod CDX-MP30 Jammed CD Replacement, Main Panels: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Phillips #0 Screwdriver
    $5.49
    구매
  3. Sony Xplod CDX-MP30 Jammed CD Replacement: 3 단계, 이미지 1/3 Sony Xplod CDX-MP30 Jammed CD Replacement: 3 단계, 이미지 2/3 Sony Xplod CDX-MP30 Jammed CD Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Phillips #1 Screwdriver
    $5.49
    구매
    • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
    • Remove side-metal plates gently.
    • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
  4. Sony Xplod CDX-MP30 Jammed CD Replacement: 4 단계, 이미지 1/1
    • Remove the black front plate of the stereo.
  5. Sony Xplod CDX-MP30 Jammed CD Replacement: 5 단계, 이미지 1/2 Sony Xplod CDX-MP30 Jammed CD Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    $5.49
    구매
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
    • Lift off the top plate.
  6. Sony Xplod CDX-MP30 Jammed CD Replacement: 6 단계, 이미지 1/3 Sony Xplod CDX-MP30 Jammed CD Replacement: 6 단계, 이미지 2/3 Sony Xplod CDX-MP30 Jammed CD Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    $5.49
    구매
    • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
  7. Sony Xplod CDX-MP30 Jammed CD Replacement: 7 단계, 이미지 1/3 Sony Xplod CDX-MP30 Jammed CD Replacement: 7 단계, 이미지 2/3 Sony Xplod CDX-MP30 Jammed CD Replacement: 7 단계, 이미지 3/3
    • Carefully pull the fuse out of the back of the stereo.
  8. Sony Xplod CDX-MP30 Jammed CD Replacement: 8 단계, 이미지 1/2 Sony Xplod CDX-MP30 Jammed CD Replacement: 8 단계, 이미지 2/2
    • Firmly grip the body of the stereo and pull off the silver back plate.
  9. Sony Xplod CDX-MP30 Jammed CD Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    $5.49
    구매
  10. Sony Xplod CDX-MP30 Jammed CD Replacement: 10 단계, 이미지 1/2 Sony Xplod CDX-MP30 Jammed CD Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    $5.49
    구매
    • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
  11. Sony Xplod CDX-MP30 Jammed CD Replacement: 11 단계, 이미지 1/3 Sony Xplod CDX-MP30 Jammed CD Replacement: 11 단계, 이미지 2/3 Sony Xplod CDX-MP30 Jammed CD Replacement: 11 단계, 이미지 3/3
    • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
    • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
  12. Sony Xplod CDX-MP30 Jammed CD Replacement, Jammed CD: 12 단계, 이미지 1/2 Sony Xplod CDX-MP30 Jammed CD Replacement, Jammed CD: 12 단계, 이미지 2/2
    이 단계에 사용된 도구:
    $5.49
    구매
    • Using the Phillips #0 Screwdriver, unscrew the two gold screws (length - 7.37mm) found on top of the CD Tray.
    • Remove the top cover.
  13. Sony Xplod CDX-MP30 Jammed CD Replacement: 13 단계, 이미지 1/3 Sony Xplod CDX-MP30 Jammed CD Replacement: 13 단계, 이미지 2/3 Sony Xplod CDX-MP30 Jammed CD Replacement: 13 단계, 이미지 3/3
    • These two pieces will NOT separate completely. They are connected by small wires on one side. So make sure you follow the pictures carefully to know which side to pull up.
    • Grip the top of the CD-Drive and pull it up and over, as shown in the pictures.
    • Notice the wires that hold the two pieces together.
  14. Sony Xplod CDX-MP30 Jammed CD Replacement: 14 단계, 이미지 1/2 Sony Xplod CDX-MP30 Jammed CD Replacement: 14 단계, 이미지 2/2
    • Pay extra attention to the spring inside the CD-Drive. This will be crucial for the next step.
    • Slowly pull up the side opposite the spring, but make sure not to over-stretch the spring. This could damage the device.
    • While the part is lifted, remove your jammed CD, and you are finished!
결론
Kyle
회원 가입일: 10/10/11
114 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-35, Amido Fall 2011 Cal Poly, Team 5-35, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G35
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 4,314
