소개
Make sure you can explore the Xplod very well.
필요한 것
Press down the release button on the bottom left corner of the face plate.
Then remove the face plate carefully.
Using the Phillips #0 Screwdriver, unscrew the 3 screws (length - 7.5mm) on the front of the device.
Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
Remove side-metal plates gently.
Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
Lift off the top plate.
Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
Using the Phillips #0 Screwdriver, unscrew the 4 dark-silver screws (length - 3.71mm).
Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
Remove the power supply on the circuit board. Please follow the iFixit soldering guide to assist you.
다른 2명이 해당 안내서를 완성하였습니다.
