소개
This guide is to show how you would replace your battery if it is malfunctioning. This guide will show you how to take off the back cover of your tablet, disconnect the wires from the logic board, and remove the battery from the tablet.
필요한 것
Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
