주요 콘텐츠로 건너뛰기
Sophix TAB-730g Speakers Replacement
필요한 것
  1. Sophix TAB-730g Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Remove the back panel of the tablet so that you can access the tablet’s motherboard.
    • First, using the #000 Phillips screwdriver, remove the screws located at the bottom of the tablet.
  2. Sophix TAB-730g Speakers Replacement: 2 단계, 이미지 1/1
    • After you have removed the screws from the bottom of the tablet, you can now slide the cover off. To do this, place your hand on the panel and firmly slide the panel in the direction that the arrow indicates.
  3. Sophix TAB-730g Speakers Replacement: 3 단계, 이미지 1/1
    • Next, find the wires that connect the speakers to the motherboard. (Follow the red marker indicated in the image.) To remove these, you will use the soldering iron.
  4. Sophix TAB-730g Speakers Replacement: 4 단계, 이미지 1/1
    • Turn the device so that the speakers are at the top.
    • Locate the leads that connect the logic board to the speakers.
    • Starting from the left, you will use the solder iron to desolder the first four leads.
    • Now you are ready to remove the old, and insert the new speakers.
결론
JT Hiquet
회원 가입일: 09/29/16
333 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-3, Harley Fall 2016 IUPUI, Team 2-3, Harley Fall 2016 회원
IUPUI-HARLEY-F16S2G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 171
