주요 콘텐츠로 건너뛰기
Replacing Spark Plugs on Mercedes Benz W123
필요한 것
  1. Replacing Spark Plugs on Mercedes Benz W123, Spark plugs: 1 단계, 이미지 1/2 Replacing Spark Plugs on Mercedes Benz W123, Spark plugs: 1 단계, 이미지 2/2
    • First, you must buy spark plugs that correspond to the engine or their equivalent. Consult the owner's manual.
    • To begin, disconnect the cables of each spark plug. Grip them by the base and pull them out firmly.
  2. Replacing Spark Plugs on Mercedes Benz W123: 2 단계, 이미지 1/2 Replacing Spark Plugs on Mercedes Benz W123: 2 단계, 이미지 2/2
    • Next, you must use a spark plug wrench. Apply force while twisting counterclockwise, until you remove the spark plug.
  3. Replacing Spark Plugs on Mercedes Benz W123: 3 단계, 이미지 1/2 Replacing Spark Plugs on Mercedes Benz W123: 3 단계, 이미지 2/2
    • Insert the new spark plug. Be careful to not let the new spark plug fall because it can alter the opening of the electrode. It is recommended to use a piece of hose or a wrench to insert it carefully, turning it in a clockwise direction BY HAND to avoid damaging the threads if inserted wrong.
    • Then tighten with the wrench until snug, without over tightening, which can cause the threads or the spark plug itself to be damaged. Remember, also, that the sparks may need to removed in the future.
    • Once all the spark plugs are adjusted, reconnect the spark plug wires and enjoy.
결론
To reassemble, follow these instructions in reverse.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Carlos
회원 가입일: 03/09/18
966 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 41
전체 시간: 3,562
