주요 콘텐츠로 건너뛰기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
Sparks plugs and/or ignition coils replacement
필요한 것
  1. Sparks plugs and/or ignition coils replacement, Accessing the engine hood: 1 단계, 이미지 1개 중 1개
    • Open the trunk.
    • Put aside the trunk carpets.
  2. Sparks plugs and/or ignition coils replacement, Acessing the engine compartment: 2 단계, 이미지 1개 중 1개
    • Unscrew the 6 T50 screws by hand or using a wrench and a socket.
    • Lift and put aside the engine hood.
  3. Sparks plugs and/or ignition coils replacement, Extracting ignition coils: 3 단계, 이미지 3개 중 1개 Sparks plugs and/or ignition coils replacement, Extracting ignition coils: 3 단계, 이미지 3개 중 2개 Sparks plugs and/or ignition coils replacement, Extracting ignition coils: 3 단계, 이미지 3개 중 3개
    • Disconnect and put aside the oil vapors duct.
    • Disconnect the ignition coils' connector.
    • Unscrew each 8mm bolts of the 3 ignition coils.
    • Gently extract the ignition coils.
  4. Sparks plugs and/or ignition coils replacement, Extracting the spark plugs: 4 단계, 이미지 2개 중 1개 Sparks plugs and/or ignition coils replacement, Extracting the spark plugs: 4 단계, 이미지 2개 중 2개
    • Unscrew and extract the spark plugs using a 14mm spark plug socket.
    • Clean off and/or dust off the debris in the zone to avoid contamination in the cylinders.
    • The Nickel/Copper spark plug shown aside is around 25.000km aged, using 100% E85.
  5. Sparks plugs and/or ignition coils replacement, Installating the new spark plugs: 5 단계, 이미지 1개 중 1개
    • Torque the new spark plug using a 14mm spark plug socket at 24 N.m.
    • Verify and ajust the spark plug gap to the considered model's spec if necessary.
    • The RTA (French Revue Technique Automobile) and spark plug manufacturers advise not to grease the spark plug's thread.
    • Do not modify an used spark plug's gap.
  6. Sparks plugs and/or ignition coils replacement, Reinstalling the ignition coils: 6 단계, 이미지 2개 중 1개 Sparks plugs and/or ignition coils replacement, Reinstalling the ignition coils: 6 단계, 이미지 2개 중 2개
    • Put back the ignition coils on the spark plugs.
    • Torque each of the 3 ignition coils' 8mm bolts at 10 N.m.
    • Reconnect the ignition coil's connectors.
결론
Congratulations ! You replaced you spark plugs/ignition coils !
다른 8명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
57%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
AntonioTwingo
회원 가입일: 08/24/22
7,572 평판
안내서 45개를 작성함
2가이드 댓글
Coucou Antonio, recois-tu mes mails ?
Fra San - 답글
Coucou, je reçois bien tes mails à l'adresse suivante:
antoniotwingo@proton.me
AntonioTwingo -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 137
전체 시간: 5,685
