주요 콘텐츠로 건너뛰기
Speaker Assembly Replacement
필요한 것
  1. Speaker Assembly Replacement, Speaker Assembly Replacement: 1 단계, 이미지 1개 중 1개
    • Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
  2. Speaker Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four T-8 screws (15 mm long) from the black speaker face.
  3. Speaker Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Pry the two rubber end pieces loose enough to pry off two pieces of the long plastic casing from the speaker body using a metal spudger.
  4. Speaker Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Pry the two remaining rubber pieces of the casing completely away from the body of the speaker with the same metal pry tool.
  5. Speaker Assembly Replacement: 5 단계, 이미지 2개 중 1개 Speaker Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Once you have removed the outer blue casing, four T-8 screws (15 mm long) will be revealed on each corner. After removing these screws, simply pull the top part of the speaker way from the body to get the the inner part of the speaker.
  6. Speaker Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Once you have gotten to the internal parts of the speaker, there are seven wires connecting the speaker plate to the body of the speaker. Pinch the release tabs at the top of each of the four main wires to remove them.
  7. Speaker Assembly Replacement: 7 단계, 이미지 3개 중 1개 Speaker Assembly Replacement: 7 단계, 이미지 3개 중 2개 Speaker Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Simply pull the thin wires on each side to remove them from their attachment points.
    • Remove the final red and black wire by gently pulling it apart.
    • This will ultimately detach the speaker plate from the base.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Shelby Ramsey
회원 가입일: 01/29/18
505 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 2,032
