주요 콘텐츠로 건너뛰기
Sphero Ollie Motherboard Replacement
필요한 것
  1. Sphero Ollie Motherboard Replacement, Tires and Hubcaps: 1 단계, 이미지 1/1
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Motherboard Replacement: 2 단계, 이미지 1/2 Sphero Ollie Motherboard Replacement: 2 단계, 이미지 2/2
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie Motherboard Replacement: 4 단계, 이미지 1/2 Sphero Ollie Motherboard Replacement: 4 단계, 이미지 2/2
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie Motherboard Replacement: 5 단계, 이미지 1/2 Sphero Ollie Motherboard Replacement: 5 단계, 이미지 2/2
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Krystal Hedrick
회원 가입일: 10/30/17
364 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S1-G3, Rose Fall 2017 UW Tacoma, Team S1-G3, Rose Fall 2017 회원
UWT-ROSE-F17S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 723
