주요 콘텐츠로 건너뛰기
Sphero Ollie Tire and Hubcap Replacement
필요한 것
  1. Sphero Ollie Tire and Hubcap Replacement, Tires and Hubcaps: 1 단계, 이미지 1/1
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Tire and Hubcap Replacement: 2 단계, 이미지 1/2 Sphero Ollie Tire and Hubcap Replacement: 2 단계, 이미지 2/2
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kakkada Tho
회원 가입일: 10/18/17
432 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G3, Rose Fall 2017 UW Tacoma, Team S1-G3, Rose Fall 2017 회원
UWT-ROSE-F17S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 3,070
