주요 콘텐츠로 건너뛰기
Spigen Kuel TS36 Car Mount Spring Replacement
필요한 것
  1. Spigen Kuel TS36 Car Mount Spring Replacement, Spring/coil: 1 단계, 이미지 1/2 Spigen Kuel TS36 Car Mount Spring Replacement, Spring/coil: 1 단계, 이미지 2/2
    • Pull the phone holder off the mount by applying force; the parts will not actually break from the pressure. Temporarily remove the two round half-socket covers on the ball socket, as they are prone to slipping off.
  2. Spigen Kuel TS36 Car Mount Spring Replacement: 2 단계, 이미지 1/1
    • Remove four 5.0 mm screws from the backing panel of the phone holder using the Oval shape screwhead. Push out wing panels to release the mechanism, and remove the screws and holder from the backing panel.
  3. Spigen Kuel TS36 Car Mount Spring Replacement: 3 단계, 이미지 1/2 Spigen Kuel TS36 Car Mount Spring Replacement: 3 단계, 이미지 2/2
    • If either of the springs have not ejected from their slots, proceed to pull them out gently so that the chassis the wing panels are connected to remain undisturbed.
  4. Spigen Kuel TS36 Car Mount Spring Replacement: 4 단계, 이미지 1/2 Spigen Kuel TS36 Car Mount Spring Replacement: 4 단계, 이미지 2/2
    • Insert two new 2.6 cm springs as you would batteries to a tv remote. Be cautious as to keep the chassis in place during this process.
  5. Spigen Kuel TS36 Car Mount Spring Replacement: 5 단계, 이미지 1/2 Spigen Kuel TS36 Car Mount Spring Replacement: 5 단계, 이미지 2/2
    • Pull out of the wing panels to re-engage the mechanism, holding the center of panels down.
    • The backing panel will not be able to properly be reattached unless the mechanism is is engaged, and the springs are bunched.
  6. Spigen Kuel TS36 Car Mount Spring Replacement: 6 단계, 이미지 1/2 Spigen Kuel TS36 Car Mount Spring Replacement: 6 단계, 이미지 2/2
    • Slide the backing panel over the frame of the holder, aligning the sides. Press the button on the center of the holder to once again disengage the mechanism. This will allow the panel to fully slide back into place.
  7. Spigen Kuel TS36 Car Mount Spring Replacement: 7 단계, 이미지 1/1
    • Rescrew backing with oval head screwdriver to reassemble the phone holder’s backing.
  8. Spigen Kuel TS36 Car Mount Spring Replacement: 8 단계, 이미지 1/2 Spigen Kuel TS36 Car Mount Spring Replacement: 8 단계, 이미지 2/2
    • With moderate to heavy force, apply pressure to the ball joint into the socket.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ramy Huynh
회원 가입일: 09/30/19
172 평판
안내서 1개 작성함
CSU Fullerton, Team S1-G1, Bruce Fall 2019 CSU Fullerton, Team S1-G1, Bruce Fall 2019 회원
CSUF-BRUCE-F19S1G1
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 26
전체 시간: 1,030
