주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Spin Master Boxer Remote Trigger Buttons Replacement
필요한 것
  1. Spin Master Boxer Remote Trigger Buttons Replacement, Remote Trigger Buttons: 1 단계, 이미지 1개 중 1개
    • Lay the remote flat on your work space, with joysticks facing you.
    댓글 쓰기
  2. Spin Master Boxer Remote Trigger Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Remove both joysticks by gripping under circular knob and gently pulling towards you.
    • The joysticks should detach without much effort.
    댓글 쓰기
  3. Spin Master Boxer Remote Trigger Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Use the Phillips #00 Screwdriver to remove 4mm screw on the center battery panel.
    • Remove the batteries from the remote and set it to side.
    • Use the same screwdriver to remove all four 4mm screws on back panel.
    댓글 쓰기
  4. Spin Master Boxer Remote Trigger Buttons Replacement: 4 단계, 이미지 2개 중 1개 Spin Master Boxer Remote Trigger Buttons Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the Jimmy in between the top panel and the bottom panel.
    • Gently use the Jimmy to separate both plastic panels from each other.
    • Pull the panels apart and set bottom piece on workbench.
    댓글 쓰기
  5. Spin Master Boxer Remote Trigger Buttons Replacement: 5 단계, 이미지 2개 중 1개 Spin Master Boxer Remote Trigger Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Pinch the trigger between index finger and thumb, and lift up, away from circuit board.
    • Inspect the square button attached to circuit board to ensure functionality. If there is an issue with connection, a new circuit boards may be required.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Lauren Roide
회원 가입일: 04/16/19
769 평판
안내서 5개를 작성함
Cal Poly, Team S1-G1, Maness Spring 2019 Cal Poly, Team S1-G1, Maness Spring 2019 회원
CPSU-MANESS-S19S1G1
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 44
전체 시간: 1,283
